Results 1 to 10 of 14
Thread: Can you read check engine codes through OBC?
    Sep 2005
    Default Can you read check engine codes through OBC?
    Hey all,
    For some reason i cant read fault codes through the check bulb ( 5 in 5 seconds stomp test ) either no power to it at all or bad bulb but i did switch it with a nother and still dead. So was wondering anyone no how to pull up the codes through the obc? can it display fault codes? im searching but to no sucsess yet. any info would be great.
    Thanks Strap
    PS: i think it should have some codes stored since it is running so rich it burns your eyes if you stand behind the car for more than 20 seconds...
    No, cannot.
    But where do you live respect. what specification is your car?
    Only US specifaction cars are quipped to do the stomp test. Not EU cars or others.
    Buy a PEAKE tool for 150 $ and that is a nice investment. I always have it in my glovebox compartment.
    www.peakeresearch.com
    Sep 2005
    No, cannot.
    Thanks Shogun ,
    Problem is im in asia , dont no if i can find it here or not, car is EU/THA version e34 m50TU (vanos) if i can get someone to send me one here i will by it.
    Ps; i was just on your site checking your rim sizes on your e34 , your rime sit real nice and im trying to get the offset right so i can order rime this week but i have to give exact spects...They are clueless at the tire shops here...
    Thanks again Strap
    I am also in Asia, in Japan.
    You can order the PEAKE from USA directly. They send it to you. I also bought it from PEAKE research directly.
    Where do you live, which country?
    I have some nice sets E39 paralell Type 82 wheels, ET 20, with tires in one of my parts cars, it is an E32 750iL.
    And another set on this car
    But it is only realizable when you live in Japan, otherwise shipping cost is too high.
    Sep 2005
    Thanks for that but im in Thailand, at least for the next few years...
    im trying to get a set of hamman hm2 ( i think ) 18x8 front and 18x9.5 or 10 rear if they will fit and sit right. fenders on the car are already rolled inside.
    Thanks Strap
    Sep 2005
    Swansea South Wales
    Stomp 5 in 5 works on my E.U. 525TDs diesel..........Should work on others too.........
    Got fault code 19.
    Forget it, EU cars do not have that, and 19 is no code. You must have a least 4 digits.
    We have discussed that over and over again.
    Here is how it goes and where you can read the codes
    http://www.europeantransmissions.com...BMW/bmwcod.pdf
    http://www.epa.gov/obd/basic.htm
    Horse Country
    Default I also tried the stomp test, but
    it seems like a really violent thing to do to the engine--run at such high rpms.
    I had no sucess with check light either with american car--bit nervous about the stomp thing, is it really okay?---should I try again?--I know thatthe light is working--maybe I just didn't stomp hard enough.
    Sep 2005
    Swansea South Wales
    Dont know about the petrol cars, but this is Definately a fault code for the DDE system They are 1 or 2 digits.
    The code is accessed in the usual 5 stomp way, and will repeat if you stomp again after its finished, One long flash, then 19 short blinks.
    Apr 2004
    trinidad, in the caribbean
    Quote Originally Posted by HDhandyman
    er,,,, the stomp test is done when the key is in position 2 NOT when the engine is running , position 2 is when the key is in the position where all the check lights in the cluster is on just before you start
  1. ABS blinking codes, how do you read them
    Last Post: 10-22-2010, 07:36 PM
  2. Check Engine codes?
    By elbasha in forum 5 Series BMW
    Last Post: 07-07-2008, 07:24 PM
  3. 91 535iA trouble check engine/codes continue
    By Rigmaster in forum 5 Series BMW
    Last Post: 11-11-2006, 07:05 AM
  4. Check engine codes
    By karl1171 in forum 5 Series BMW
    Last Post: 08-19-2004, 05:43 PM
