Results 1 to 7 of 7
Thread: Getrag 280/260
    Aug 2005
    Newton, MA
    Default Getrag 280/260
    Do these transmission have the same bolt pattern?
    I really need to know because im still hoping to replace my auto tranny with a 5-spd Getrag 280. And I know that a 260 is a direct bolt on for an M50 engine..
    Jan 2005
    Sicily
    Yes i think so, you should not have to change anything, but i could be wrong, just the gear ratios are different i believe
    Aug 2005
    Newton, MA
    Quote Originally Posted by e34it
    Alright, I will hopefully be getting the tranny sometime friday.
    If anyone has a suggestion for transporting a car from PA to MA, please let me know. Other than that I would like to know if a complete drivetrain and some interior pieces and all doors would fit in a van that has 127cu. inches of cargo space. And a ~1600 lb maximum weight capacity...
    -Artem
    If the price is right and the parts are actually good, you should buy it, regardless (because you can turn around and sell it, maybe even to some of the nutcases on this board ). But the 280 for an M5 won't fit an M50 or an M20 -- the M20/M50 bellhousing is different and the engine physically sits about 10 degrees off of where the M30/S38 sit. The manual trans for your car is the Getrag 250, which can readily be found for little money.
    Good luck!
    best, whit
    Aug 2005
    Newton, MA
    Quote Originally Posted by lowell
    Good luck!
    best, whit
    Great, Thanks a lot! :-)
    Its still quite a drag for me to get out there... So im still considering... Price is really low --> but its basically a Transmission, Driveshaft, LSD, subframe and a real self leveling suspension (which people would easily let go for a set of regular shocks), plus a set of Throwing stars. And an engine block that is really an M30 that has been bored out to a 3.6 liter displacement in a nutshell...
    PS --> There are a LOT of 80s 325E/i's on the junkyards that are nearby here, in Mass. I was thinking about doing a transplant of one of thosein my car. Would that work? And also would it be a good step to do something like that? (I dont really know what kind of a manual transmission is in the 80's 325E's or I's
    Yes, a 260 from an E30 325i should work at the engine side of it, but I don't know about the output flange.
    The M50 manual tranny is the S5D 250G (EDIT: or the S5D-310Z found with the earlier non TU engines), Getrag calls it a 220/5. They're readily available on eBay and other places....I'm sure you'll have no problem finding one. Using that trans will save you a lot of hassle in finding a driveshaft that will work.
    Best, whit
    Aug 2005
    Newton, MA
    Thanks. I will make sure to remember the 220/5. Might do a swap sometime next summer as I might have better funding then.
    -Artem
  1. Transmission getrag 260
    By bimmerred535i in forum 5 Series BMW
    Last Post: 06-06-2009, 09:48 AM
  2. Trans oil...'90 525 M20 Getrag 260/5...
    By yaofeng in forum 5 Series BMW
    Last Post: 04-30-2008, 12:23 AM
  3. Getrag 290/5 in my car?
    By beetos in forum 5 Series BMW
    Last Post: 08-21-2006, 03:50 AM
  4. Getrag parts
    Last Post: 03-30-2006, 10:09 PM
  5. Has anyone used a Getrag 265 in a 535?
    By Chris in Laguna Beach in forum 5 Series BMW
    Last Post: 05-09-2005, 08:41 AM
