Is that just the bulb or the headlight assembly?Originally Posted by Curt Anderson
My M5 has NAL (North American Lighting) branded headlights which I know nothing about. The parent company for NAL is Koito Manufacturing based in Tokyo. Does anyone know anything about this brand, good or bad?
TIA,
Curt.
Curt.
1994 530iT (gone but not forgotten since I see it every day!)
1991 M5
There is "NAL" cast in the center of the lenses, both high and low beam.
Curt.
Curt.
1991 M5
I have em. Canadian 91_525im. I think they suck the big one
The first person to offer up some better lighting at a reasonable pric will make some money
Dave M
Koito is a big OEM supplier for Toyota. They manufacture both headlamp assemblies and bulbs.Originally Posted by Curt Anderson
Nothing wrong per se with the brand...IMO, far better in fact than anything manufactured in Taiwan or China.
Ken F.
'91 535i
'95 540iT
'02 C180
'01 CBR600F4i
I've never taken the lights out of either e34 but can I install any 5.75" diameter light? Or are the buckets a special design that requires a special light? Except for the Touring, which has elipsoids, just about every car I've ever owned got Hellas or Cibies put in while I owned them and I'm thinking of doing the same here if I can. Comments?
Curt.
Curt.
1991 M5
i think i have hella?
89-90 and 93-95 have the elipsoid projector lights and they are expensive to replace, usually hella brand, 91-92 have cheeper less effective lights, the high and low beams look the same and don't have the dark dot that the elipsoid lowers have. elipsoids are as good as usa lights got and are varly close to euro lights in quality of beam but don't give you the option to install higher wattage bulbs
my '93 had us non-ellipsoids, 10/92 prod date.Originally Posted by winfred
the factory was ether using up old stock (not sure when the cut off point was) or it was hit and repaired with the earlyer lights
Originally Posted by bimmerd00d
