Results 1 to 7 of 7
Thread: overheating problems 89 525i
    cal Guest
    Default overheating problems 89 525i
    I put in a thermometer and bled the radiator and thermostat but the car is still overheating. It takes forever for the temperature guage to get to the halfway mark. When it does it eventually goes into the red. Any ideas?
    Los Angeles, California, USA
    cHECK ALL YOUR HOSES.
    mY FAN WAS SLICING INTO ONE OF MY HOSES ADN I COULDNT EVEN SEE IT, SMALL HOLE.....dEFINETELY FIRST THING TO CHECK.
    Hi, my name is Eric......and I am a BMW-aholic.
    Unregistered Guest
    I am new to car repair. How can I tell if a hole is in the hoses.
    Quote Originally Posted by ///M Power
    SoCal
    Default It could be several things
    Best bet it to goto Bruno's site and read up on it.
    http://www.bmwe34.net/e34main/trouble/overheating.htm
    Canada, ON
    Default Check a couple of things for us
    Quote Originally Posted by cal
    The 525i is hard to bleed... You need to follow the procedure in BMWE34.net.
    Meaning blowing with your mouth in the radiator filling neck and bleeding the thermostat housing bleed screw then the radiator bleed screw.
    Ok, you need to find why the car overheats... Could be many things.
    Tell us if it overheats at idle or any other time
    Unregistered Guest
    If the radiator is clogged will it possibly cause this problem. The coolant doesn't get hot in the radiator when the car overheats.
    Quote Originally Posted by Bruno
    Canada, ON
    Could be the radiator or the thermostat. I will start by changing the thermostat (cheaper) then BLEED the circuit. follow the instructions I gave you.
  1. 92 BMW 525I overheating
    By bad2buck in forum 5 Series BMW
    Last Post: 04-23-2009, 03:05 PM
  2. Noob with E34 problems (overheating)
    By Chriszea in forum 5 Series BMW
    Last Post: 08-10-2006, 07:48 AM
  3. E34 520i 24v major overheating problems.
    By Bob Gorsuch in forum 5 Series BMW
    Last Post: 09-22-2004, 12:50 PM
  4. Overheating 525i 96
    By fenhow in forum 5 Series BMW
    Last Post: 07-12-2004, 04:37 AM
  5. My 93' 525i still overheating.
    By ACir in forum 5 Series BMW
    Last Post: 05-22-2004, 05:53 PM
