the most common leak point on a m50 is the 2 lines coming off the valve cover, the little one goes to the fitting where the idle control valve connects under the intake, and the big one goes to the air boot, the line can rot off and the boot can split where the line connects. it's also possible that the idle control valve needs to be cleaned, i clean them with carb cleaner
