Originally Posted by
Alexlind123
My fuel gauge is stuck at a little above 1/4 and my speedometer intermittently fails. Both instruments work when testing the intrument cluster by turn the key to position 2 with holding the button (speedo only goes to around 80 but it always does that on the test). My question is, what should i do first? Remove the sender from the gas tank and inspect/clean/replace it and also remove the sensor from the differential; or, as my brother suggested, take the cluster out for him to resolder?
