I borrowed one (for free) from Auto Zone. Wouldn't want to do it without one. I believe it was for a Ford 5.0, but someone else can verify that. Then I purchased the thin 32mm from a bicycle shop.Originally Posted by acyre
How important is the "special" fan clutch tool to the overall experience of replacing the woter pump?
If you're wondering why I'm still talking about this, it's because I'm waiting on the seal plug for the radiator to come in. ARGH!
-ashley
Paper Gaskets Suck!
1990 535i 5-sp., except for 16" M-Contours, cd deck, and clear corners, completely stock. 226k and running strong
Do you mean a cone wrench???Originally Posted by Mitch90535im
-ashley
Paper Gaskets Suck!
My brother made me one at his work. It's amazing how often that thing needs to be removed or the job's just easier with it removed.Originally Posted by acyre
It also fits in the tool kit in the trunk.Originally Posted by uscharalph
I drew a template of the one I borrowed from Auto Zone. Just haven't got around to making the tool yet. I bet you could make one out of wood and it would work jut fine.
If its 32mm wrench, its an old-school headset wrench like this one:Originally Posted by acyre
http://www.parktool.com/parktoolgear...&item=HCW-7OLD
Definitely alot easier with the tool.
That 32mm is for the nut. The "special tool" is to hold the pulley while you loosen the nut. Remember that the nut is reverse-threaded too. Park also makes a longer version if this same wrench.Originally Posted by bfd
