Results 1 to 10 of 14
Thread: heater valves disassembled
    Nov 2004
    Middle England
    errr ... just maybe I ought to clean mine
    '90 535iSE Auto (AE+EAT) 123k miles
    '86 F288 69k miles
    '06('89)- PGE 2.0DOHC Turbo
    '03 A160LE 19k miles
    1914 Stellite E2A (no odometer!)
    (+ others I daren't mention here)
    www.pyghtle.com
    Default I recall that while you can take...
    Humptydumpty apart, you can't put him back togethere again.
    (AKA - it's a non serviceable part)
    Quote Originally Posted by zygoteer
    Bellevue WA
    86 Porsche 951 - Track Toy
    new one looks a bit better
    Bethlehem, PA
    Do you know, by any chance, how well this cooling system has been maintained over its lifetime? IOW, is the condition of this valve a result of only one or two coolant changes in the car's lifetime? It would be sort of interesting to see what the valve looks like from a car that's had new blue stuff every two years.
    Default Jeff
    I do not mean complete disassembling, just clean that part. See first pic and this one
    ok I follow, thats a big difference!
    Gee, they're kludged but it looks like they'd still work.... (perhaps NOT)
    How much the PO sucked u can tell from the cooling system, always.
    Trouble with most is by the time they are this 'kludged-up' the shaft seals are gone and the solenoids have filled with coolant- over the space of a few years causing a terminal 'oxidisation+kludge' problem fixable only by replacing the solenoid (or more often the valve itself).
    My valve body refused to divide very well (it is very easy to have it come off crookedly and thus break the shafts on the little valves) though I think mine broke in use as I noticed the broken bits before I it blew apart. See my previous posts on them for pics.
    Nick
    ps. If anyone has an old valve, PM me, I need one of those two little valves from inside to make mine work!
    Long Beach, CA
    Kentucky
    What's the usual life span on those ? I have no record of mine being replaced by the PO (that I can recall anyhow).
  1. ever seen such dirty heater valves?
    Last Post: 11-06-2013, 08:24 AM
  2. heater valves or aux pump
    By Paul in NZ in forum 5 Series BMW
    Last Post: 07-29-2006, 07:09 AM
  3. Replies: 4
    Last Post: 06-01-2006, 04:23 AM
  4. Heater valves disassembled - pics
    Last Post: 11-28-2005, 01:35 PM
  5. Heater Valves
    By Rory535i in forum 5 Series BMW
    Last Post: 09-19-2005, 05:46 AM
