Results 1 to 10 of 17
Thread: It thinks the key is in ignition, won't start - HELP!!
    Jun 2005
    Cleveland, OH
    Quote Originally Posted by ChefJRD
    Assuming I eventually get the cylinder out, will I be able to start the car with a screwdriver until I get a new keyed cylinder?....
    Yes / No... a 95 will have EWS... ie the key has a microchip, you should be able to stick the key and and then turn over the car with a screw driver, however....
    You still got to deal with the steering wheel lock and if she is an auto the tranny lock.
    edit:after looking it looks like they are still working correct if you can turn the part after you pull it out... not sure on that however...
    Charles
    I miss my e34
  1. Car thinks door is open
    By bimmerboy in forum 5 Series BMW
    Last Post: 10-28-2008, 02:52 PM
  2. Ignition won't go to "start" position?
    Last Post: 12-18-2007, 06:13 AM
  3. Ignition fuse blows after each start up.
    By mossyoaks in forum 5 Series BMW
    Last Post: 05-17-2006, 12:38 AM
  4. My car thinks it's really, really cold outside
    By Mitch90535im in forum 5 Series BMW
    Last Post: 05-01-2006, 02:59 PM
  5. key won't rotate in ignition switch or start car
    Last Post: 03-12-2005, 10:59 PM
