Originally Posted by
billb
Yesterday I had a friend with a '97 328i down for a lookover. We were going to do filters, plugs, and belts. Ran out of time for an oil change. First off, under the hood was NASTY. Pulled the cam shrouds off, blew out the holes for the plugs, then proceeded to pull out six AUTOLITE PLATINUMS!! Ugh. Back in with the proper NGKs. Pulled out the old air filter, BMW stock, made in 1999, so I'm guessing it hasn't been changed in at least 3-4 years. Then on to the A/C belt, which was making a racket. First, we found the radiator fan shroud, which also holds the coolant expansion tank, was loose and not attached to the radiator on one side. Fixed that, then pulled the old belt off. I've never seen so many cracks in a belt. New one quietened everything right up. Then on to the fuel filter, again with a mfg. date of 1999. Put a new one in no problem (takes a little longer than an E34 or E30 due to the covering on it). Then, for my favorite part, squirting under the hood with some Greased Lightning, then washing it down. His words were "Wow, I didn't know it could look "clean" under the hood".
Mission accomplished. Now, to start working on shortening his oil change intervals to desludge that nasty beast inside...
On another note, the neighbor's 325i has a squeak in the brakes. Guess I've got some warranty work ahead.
