Results 1 to 10 of 10
Thread: Heater control valve repair (Shogun?)
    Jun 2005
    Davis, CA
    Default Heater control valve repair (Shogun?)
    I thought it was on this board but I can't find the post now. Maybe it was RF? At any rate I was reading about the heater control valve and if memory serves me right it was Shogun who mentioned that 735i with a build date of 3/88 or earlier came with a heater control valve that is repairable like the old e28 heater control valve.
    Well, I was junkyarding yesterday and came across a 2/87 build date 735i with the heater control valve intact. It is indeed repairable with repair kits that are ~20 per side so ~40 to repair both. I picked it up with the coolant pump for $4.94. I also picked up a later model heater control valve out of a 3/88 735i minus the pump for the same price. Not sure if I have the dates wrong or this one was replaced with later model. Both seem ok in that if you shake them gently you can hear the valves moving. Mine is stuck open which seems to be the typical failure mode. I'll check them out better this weekend when I replace the leaking radiator and hopefully replace the bad heater control valve.
    Craig in Davis
    89 535i auto to manual conversion
    Delphin-Metallic/Black leather 296k
    83 533i 5 speed Alpinweiss/Cardinal Red leather 236k
    damn thats a good point you made about shaking it to see if they move...dammit im too late.
    Default Yes, you shake them + can hear it
    I have a set from 1988 in the box next to my PC. Changed them last year when the aux water pump went south, but the valves are still o.k.
    I have no more direct info about the repair but the old one are repairable and there should be repair kits.
    In such case just check on my website what is available.
    Here a direct link to Johan's write up
    http://shrubbery.student.utwente.nl/...tervalves.html
    Jun 2005
    Davis, CA
    Default The picture at the top right of the page is what the
    repairable heater control valve looks like. I found the repair kit at carpartstogo.com
    Craig in Davis
    Mar 2004
    Brisbane, Australia
    My car was manufactured 12/88. would that be the same as the 7 series? i recently took out my old heater valves that didn't work properly and replaced them with another second hand set that don't work either Where can u buy the repair kits from?
    Mar 2004
    Brisbane, Australia
    Never mind, just saw the picture of the repairable ones. not the same as mine unfortunately.
    Wellington,New Zealand
    will the replaceable valves fit the new style.....i have occasional blasts of full heat from the drivers side........man what a heater!
    Gone but not forgotten
    Jun 2005
    Davis, CA
    Default No the valves are very different. eom
    Quote Originally Posted by Paul in NZ
    eom
    Craig in Davis
    If anyone has a new type valve (yes, the non-repairable type) ie the actual valve part from inside the valve assembly (its the the brass cone with the little stick on it that tends to break) or;
    a compete or semi-complete new type assembly that was removed due to malfunction, I'm sure in need, feel free to PM me! Nick
    ie There are some circumstances in which the new type valve can be repaired (only if you have broken shafts and no-leak), however new parts are not avialable separately, hence my post to scavenge others' throw-outs..
    Items for sale from ferrulli_motor_works
    BMW heater control valve kits
    ferrulli_motor_works | eBay
    BMW Heater Control Valve Repair Kit E32, E34, E38, E39, M5 & X5
    US $79.99
    This just for the case that someone is still loking for these repair kits.
    Since I repaired old heater valves before and I know how brittle the plastic gets after more than 15 years and the probability that the plastic hose connections break is high, I will not buy them. Better wait for the special offers at the online shops, last a cpl. new Hella heater valve I bought was $120, and that lasts again another 15 years.
  1. Ever repair a broken Heater valve wire?
    By Jehu in forum 5 Series BMW
    Last Post: 04-11-2008, 08:37 AM
  2. Replies: 9
    Last Post: 11-01-2007, 09:54 PM
  3. Heater Control Valve/s replacement
    By DCR in forum 5 Series BMW
    Last Post: 02-10-2006, 01:00 PM
  4. possible to repair heater valve/pump?
    By 8 POTS in forum 5 Series BMW
    Last Post: 09-13-2005, 04:50 AM
  5. Finished with Heater control valve overhaul
    By Loke in forum 5 Series BMW
    Last Post: 06-23-2004, 05:07 PM
