Originally Posted by
pfmc24
Hi, new member requiring advice..................
I recently had a head gasket replaced, caused by blocked radiator. I sourced a second hand radiator which was guaranteed for 90 days, but the car still overheats in traffic.
My local garage say the radiator is corroded internally (they got it tested), and does not dissipate enough heat.
I'm also not sure if it was the correct type replacement, the radiator looks thinner than the original.
Is this the cause of the new overheating problem?
Car is a 520 1989 automatic, and has had a new stat, water pump, fan clutch and head gasket (and head skim).
Any advice would be most welcome, as I would like to get a refund on the replacement radiator!
