Results 1 to 3 of 3
Thread: Intake manifold temperature sensor
    Nov 2004
    Split, Croatia
    Default Intake manifold temperature sensor
    OK, I just measured the resistance of the sensor on a fully warmed up engine on a mild day (20°C) and it read 870 Ohm - is this normal? The ETK says it's a 2500 Ohm thermistor but I don't know is it PTC or NTC and what is the temperature range.
    Anyone?
    did you measure the resistance when cold? Thats when most measurements are taken.
    Nov 2004
    Split, Croatia
    I'll try that today when I get back from work. What value should I get when cold if my sensor is working properly?
  1. m50 intake manifold
    By shadowpuck in forum 5 Series BMW
    Last Post: 03-09-2008, 12:39 PM
  2. anyone want a v8 intake manifold - used???
    Last Post: 01-08-2005, 08:49 PM
  3. Intake Manifold
    By jj7 in forum 5 Series BMW
    Last Post: 11-28-2004, 12:18 PM
  4. Temperature Sensor
    By ivenos in forum 5 Series BMW
    Last Post: 03-09-2004, 07:26 AM
  5. Why would there be oil in the intake manifold?
    By Anton CH. in forum Engine & Drivetrain
    Last Post: 02-14-2004, 09:12 PM
