You don't adjust that one. IIR, there are 3 mounting screws on the headlamp housing. 2 you can adjust and the last one - the one in the picture - is a pivot. The other two should be on an x-y axis.
Yes, i know...im an idiot.
So...how do you adjust this screw to go further in or out?
www.KaRealtySF.com
Bellevue WA
86 Porsche 951 - Track Toy
Originally Posted by Jeff N.
how would you be able to move the light as a whole- backwards...into the car...so that its flush against the body and not sticking out past the black plastic surroundings.
in this picture, you can see the headlight sticking out past the black surrounding exposing the chrome and making the car look bug eyed.
www.KaRealtySF.com
You can replace the not adjustable one to adjustable one. Then you can move the whole light in or out. Only it will be hard to aim the lights. I have move my low beam into the car more by using 3 adjustable screws.
any clue how to get those screws out? they are some pretty tuff buggers.
www.KaRealtySF.com
That looks perfectly normal to me. I think you are trying to recess it unnaturally far inside the grille. Every e34 I've seen has the chrome bezel sticking out there. It doesn't make me think it looks weird, the light is angled nice and straight 'sall. I'm usually one for the aesethics, but this seems to me to be perfectly normal and easy on the eye.. but it's just my 2c worth! Nick.Originally Posted by liquidtiger720
Here. Example. I can't figure out whats wrong!!! help!
www.KaRealtySF.com
The upper looks correct, the lower looks wrong.
Bellevue WA
top ones pointing at the sky, bottoms pointing at the ground too.
Thanks guys. And Jon. Got it done. I just jumped the gun and forgot about left / right alignment.
www.KaRealtySF.com
