Results 1 to 10 of 12
Thread: How much fluid in power steering system?
    Jul 2004
    Default How much fluid in power steering system?
    I have a 90 535i, 5 spd, 102K. The hose from the reservoir to the power steering pump is leaking. I plan to replace the hose. The reservoir states to use only ATF oil.
    However, since I will be basically draining the reservoir and part, if not all, of the pump, how much ATF fluid do I need? It looks like 1 quart would be enough? Thanks!
    Nov 2004
    Hi Shogun,
    My E34 is using CHF 11s which I believe is pentosin. Can I flush that out and replace with ATF completely ???. That CHS stuff is expensive and ATF is cheaper. Would the system is only built for CHF and not ATF ?. Pls advise. Thx.
    Aug 2004
    Milwaukee, WI; Chicago, IL
    Quote Originally Posted by emw525E34
    Hi Shogun,
    I wouldn't cheap out... BMWs in particular seem to like their prescribed fluids.
    1990 BMW 535i 5 speed - Black on Grey, LSD
    Tampa Bay, Florida, USA
    Default Chf 11s
    CHF 11S is not interchangeable. as far as I know.
    Hi Shogun,
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Jul 2005
    Exeter, Devon, UK
    ATF is for cars WITHOUT self levelling suspension. If it states use only CHF, then only use CHF.
    Do NOT use other oil as specified. I know of a lot of cases where people with LAD used by mistake ATF and they had a lot of trouble. Leaking gaskets etc.
    If you use the search on roadfly E32 board for this you will find a lot of info.
    Even some BMW without LAD need Pentosin CHF. For example the E32 730V8 has Pentosin, because the power steering pump is a different type. And that is also in your car the case.
    Will be a costly trial.
    Nov 2004
    Thanks. Pentosin it is then. Yes, I did recall the pump design. Don't know which is better but I am sure the ATF powered steering wheel is LIGHTER than the Pentosin one. At least in my experience. Kinda like the meatiness of the steering rather than the Honda-like feather weight!.
    Thanks all. Shogun. Appreciated.
    BFD --
    Buy three quarts of ATF. Flush the system with one, fill the system with another, keep a third in case anything comes up.
    I've outlined the process for flushing the system a number of times over the past few months. A search on the matter should produce the process...
    On using the correct fluid: read my recent thread on the clown who stuck the wrong stuff in his 525.
    best, whit
    Jul 2004
    Quote Originally Posted by lowell
    BFD --
    best, whit
    Thanks for everyone's response. One last question, If my car requires Dexron II ATF fluid, would putting in Dexron III hurt anything or do I need to find Dexron II? Thanks again.
  1. Low power steering fluid
    By russiankid in forum 5 Series BMW
    Last Post: 11-11-2008, 09:27 PM
  2. Power Steering Fluid
    By pgrindstaff in forum 5 Series BMW
    Last Post: 01-28-2007, 08:27 PM
  3. Power steering fluid/ ATF
    By tsteeves in forum 5 Series BMW
    Last Post: 03-24-2006, 10:43 AM
  4. Power steering fluid
    By BM-BOY in forum 5 Series BMW
    Last Post: 07-14-2005, 04:51 PM
  5. Power steering fluid
    By Mas (UK) in forum 5 Series BMW
    Last Post: 06-21-2004, 11:33 AM
