Is your M60 a nikisil or alusil block?Originally Posted by Rahimseven
Is there any guidence on changing valve stem seals? I get puffs of grey smoke every time I start the car and after reading I feel it's the oil seals. Any DIY help out there?undefinedundefinedundefined
i need to do those too, but i doubt it's easy.Originally Posted by Rahimseven
step one: remove cylinder heads
step two: cry
step three: remove cam shafts and whatnot?
step four: use special tool to remove stem seals
yeah, i have no idea but i'd guess that's about what you do. I think winferd said he could do it without removing the cylinder heads, but i imagine it's a lot "harder" that way, in terms of space.
If you could change them with the cam shafts still attached it'd be easy, like on the M70 , but i think our DOHC's ruin any hope of it being easy and simple.
Oh, and by the way, check out this write up about changing the valve stem seals on am M70, its very very interesting.
http://shrubbery.student.utwente.nl/
on the left side, there should be some menus, just navigate till you find it.
Last edited by infinity5; 09-24-2005 at 08:08 PM. Reason: left? right? which is which?
I have never heard of doing this on a M60 especially with that fresh of an engine...dino oil pays off again? Do a compression test at least before you do anything.
Probably the PCP valve is all clogged dumping raw oil into the intake.
yea another vote on the breather valve on the back of the intake being dead, it's replacement has been documented several times here a search should bring you up to speed
Thanks I'll look into those possibilities first.
