Results 1 to 10 of 10
Thread: Battery question
    WI
    Default Battery question
    Replaced the dying battery in the pumpkymobile (95 540) today. Got a Duralast 49-DL battery from Autozone per the board recommendation. However-
    The battery holddown is right over the vent on the battery. Do you trim the bit that comes in the kit with the battery so it sits more flush/not compressed by the holddown?
    It's a tight fit, but work around it. The clamp shouldn't restrict the vent tubing.
    best, whit
    vent?...tubing???? Hope I dont flip my car.
    Long Beach, CA
    I hope you don't either Jeff!
    Nov 2004
    Oh my...I hope you're not saying your battery is NOT hooked up to the vent hose...that could be disasterous!
    The battery can explode if the gases it gives off can't escape...here's what happened to an e38 owner whose battery (in the trunk) wasn't connected to the vent hose...you don't want to have to neutralize all that corrosive battery (acid) fluid that gets flung when the battery explodes:
    Q
    95 525iT / 97 740iL
    Jun 2005
    Sammamish, WA
    Quote Originally Posted by Shankster
    Not sure of the battery compartment on yours is same as mine. Just put this exact battery in my 92 535i. Just enough clearance and the vent tube isn't compressed by holddown.
    1992 BMW 535iA trying to become The Ultimate Driving Machine
    2001 Volvo V70 T5 ASR Our first Volvo. Wife says we are Volvo for Life
    Sammamish, WA
    Actually, the real fun with the 49D is the positive cap, which continually pops off due to the multiple leads running from various locations off of the body harness positive terminal. The thing should, theoretically, be capped. While reinstalling the pass side rear power seat on an E32 a few weeks back, I managed to momentarily ground out the battery because of a missing positive cap -- silly owner had destroyed the seat base by using force instead of a brain to remove it. That's a rare occurence, but still par for this course.
    best, whit
    Lowell,
    I tried to install a 100AH battery under the pass rear seat of my Highline. Instead of the standard height of 175 mm it is 190 mm. It does not fit all all, cannot get the seat properly fixed. Tried with a connector extension and slightly moving the battery in the tight space, no chance at all. Have to sell the battery again. It fits however on E32 with non electric seats, there is a bit more space.
    Nov 2004
    You could...but I wouldn't/didn't "trim the bit (I assume you mean the tip that attaches to the battery's nipple) that comes in the kit"? When you insert the vent tube over the battery's vent hole...just make sure that it is pushed up on the battery as far as it can go. The hold down bar does look like it may pinch the hose...but it kind of rises upward over that area of the battery...just be careful that you are not pinching the hose against the battery and you'll be fine.
    Q
    95 525iT / 97 740iL
    Bethlehem, PA
    If they didn't give you one with the battery (which they should have), there's a kit available with a right-angle adapter that fits under the hold-down without pinching.
  1. battery question
    By bobchiba in forum 5 Series BMW
    Last Post: 08-13-2008, 08:52 AM
  2. Battery Question
    By tjar66 in forum 5 Series BMW
    Last Post: 05-19-2008, 07:27 AM
  3. battery install question
    Last Post: 07-16-2006, 11:25 PM
  4. A battery question
    By Chad535 in forum 5 Series BMW
    Last Post: 10-03-2005, 10:42 AM
  5. Battery Question
    By AG535 in forum 5 Series BMW
    Last Post: 03-22-2004, 08:31 AM
