Has anyone noticed that there are a couple of different fuel pump designs for the E34? In particular, early E34's, M20 & M30, seem to use a design that has a attached fuel pressure regulator on top of the fuel pump. The outlet line comes out horizontally. It seems in 92 this design changed to a different pump without the externally attached fuel pressure regulator that has an outlet hose that comes out vertically. I decided that at 183k miles in my 92 M50 it might be a good idea to replace the pump as a preventive maintenance measure. When I pulled it out it was the earlier design but the hose clamps were replaced on both the outside and underside of the assembly as it bolts to the gas tank. I'm thinking someone swapped in an earlier pump at some time in the past. I looked through a number of different online part sources for the fuel pump and they list both designs as being correct for a 92. My car seems to run fine with the only noticeable problem being a slightly rough but solid idle at about 550-600rpm. I account that to be probably the injectors being old. My main question; is the later design fuel pump eqipped with an internal fuel pressure regulator or is there another fuel pressure regulator (m50 engine) somewhere else? I think all the engines require about the same fule pressure to operate properly. The earlier M20 & M30 engines have the fuel pressure regulator on the injector rail so it seems a little strange there would be two on the car. Perhaps the one on the pump isn't actually a fuel pressure regulator but more of a one-way valve to stop fuel from returning to the tank when the engine is shut off? Thoughts?
Thanks.
Paul L
PS Mounted second set of new 18" tires from the Tirerack two days ago (first set out of round) and already picked up a screw and had a flat. @#$%!
Sometimes you can't win.
