Results 1 to 10 of 11
Thread: 535i head gasket replaced...still overheating
    Jul 2005
    Default 535i head gasket replaced...still overheating
    we bled the system. After running 13 quarts of oil through, trying to get rid of the sludge, it is still overheating. It also still seems like there is water in the oil.
    What else could be wrong??
    First, I'd put a hole in the 'up' arrow of the thermostat to make coolant bleeding more secure. Then, I'd check all the coolant hoses at the firewall, for slight leaks. Then, blow through that 1 narrow hose going to the top left side of the radiator.
    Were the threads in the block cleaned up for the head bolts? The residual crap can crack the block when left in there during head torqueing.
    Then, something could be cracked.
    erased due to slander
    Jul 2005
    Quote Originally Posted by Martin in Bellevue
    The head bolt holes were cleaned out.
    did you inspect the head and block closely whebn it was apart for micro cracks? Also did you torque everything down right and retorque after the engine warmed and cooled back down? If not that could be a problem as long as you didnt over heat it again.
    Quote Originally Posted by bergie33
    Are you getting water in your oil or oil in your water?
    If #1, you could have a cracked head or block or bad head gasket. Ouch.
    If #2, it may just be that you really need to flush out the system like Martin said. It may be hard to bleed it out if it's all plugged up.
    I'd consider a pressure test on the cooling system to see if it's tight. Also, start the car cold and remove the coolant cap. Put your hand over the hole. Got pressure and/or bubbles? Headgasket's not sealing.
    Guessing it's just sludge in the system + no good bleeding.
    jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    Long Beach, CA
    What other cooling items did you check before you replaced the head gasket?
    Jul 2005
    Quote Originally Posted by uscharalph
    What else is there to check? I though water in the oil could only mean a head gasket. Didn't check anything else.
    As asked above, I did not re-torque after heating up and cooling off the engine, so I will try that.
    The head was pressure tested by the machine shop, which should have revealed any cracks. The block was inspected briefly, but not pressure tested.
    Long Beach, CA
    This may be stupid, but did you change out the radiator cap? I think they only have so many overheats in them.
    Jul 2005
    No, but there appears to be significant coolant loss, so it is not just heating up, but it is losing coolant.
    And no, I didn't change the radiator cap.
    Supposed to at least check the thermostat in bioling water and replace the waterpump as they are normal maintenance items along with all the hoses and belts.
  1. new oil leak! Replaced pan gasket
    By KeithW '91 535i in forum 5 Series BMW
    Last Post: 03-30-2008, 02:49 AM
  2. milled head + euro motor = thicker head gasket?
    By 31Hertz in forum 5 Series BMW
    Last Post: 07-30-2007, 05:50 PM
  3. Head gasket question--535i with M30 motor
    Last Post: 09-28-2006, 11:29 AM
  4. Blown Head gasket / Cracked head M50 Vanos
    By MotoMan in forum 5 Series BMW
    Last Post: 03-09-2005, 12:46 AM
  5. Replies: 3
    Last Post: 04-20-2004, 07:01 AM
