How else would you turn the high beams on, other than pushing/pulling the lever? That's how you do it on every car i've ever driven.... Or am I missing something with this post....
Just saw a typical moron obliviously driving a GM car with his high beams on and it reminded me of the clever design detail incorporated into every BMW I've owned since the '76 2002: When the high beams are on, the lever is farther from the steering wheel than when the low beams are selected. Even if your high beam indicator lamp is burned out you know whether you have the lows or highs on based on the fact it is a longer reach to the signal lever. This, of course, assumes you use your signal lights...
Anthony
03/64 production
In GM cars (most of them at least), you pull the stalk towards you to engage high beams, and pull it again in the same fashion to disengage them. The stalk always returns to the same position is what he's saying. On BMW's, it's further away from you when engaged. Even Ford figured this out.Originally Posted by Dan in NZ
the high beam switch was a big button on the floor next to the pedals.
I had a old ford pickup that the switch was on the floor board... (yes it was that way from the factory, it wasn't a charles mod). She was a stick so I did blind people every once in a while...Originally Posted by Dan in NZ
-Charles
I miss my e34
I remember that!Originally Posted by Blitzkrieg Bob
Yep, drove the 'big button' as a teen in a motorhome from Toronto to Bisbee Arizona. I still crave the power of the halogen at my feet.
Good times,
Dave M
*RIP Oskar the DOG*
well now if you have $$ you do'nt even need to worry about petty little things like "brights" BMW will turn it off for you heh. (the new 7).
-amir
You have a BMW, you dont need to use the blinkers + theyll last so much longer.
Originally Posted by xphilter
my 1973 Corvette had this, i LOVED it.Originally Posted by Blitzkrieg Bob
