Results 1 to 9 of 9
Thread: The neverending story
    Nov 2004
    Split, Croatia
    Default The neverending story
    Guys, I'm getting a feeling my car is a money pit! My rear axle carrier is bent (rear left wheel is closed an inch), I need new shocks, center and rear muffler! I'm currently accepting donations since my car is spending more than I'm earning!
    Eh, sorry for the rant, I had to get it out of my system
    Jul 2005
    Exeter, Devon, UK
    Cheer up! At least you don't have my car!!
    Sep 2005
    Germany
    Interceptor,
    I feel your pain. If its any consolation, everything you listed as needing replacement (OK, except for the rear axle carrier. That's a new one) are things that any used car your 525i's age is going to need. It's almost always cheaper in the long run to keep an older car running than to buy a new one.
    Nov 2004
    Split, Croatia
    Quote Originally Posted by BM-BOY
    Well, considering how much you payed for it, you've got much better bang for the buck than me! I payed $5500, invested $2000 more, and still going! Probably another $1000.
    Nov 2004
    Split, Croatia
    Quote Originally Posted by JT520i
    Interceptor,
    I just found out that my MAF might have gone south... *g*
    Other stuff to do:
    - all 4 door seals + sunroof seal
    - headliner cloth replacement
    Ontario-Canada
    Meh, that's not too bad...
    I bought mine last October for $5300, have spent $2000 in repairs (all flushes/incl.tranny, hanger bearing, motor mounts, tranny mounts, thrust arms, steering arms, steering links, belts, OBC, switches, dash bulbs) and I still have to replace Gas Tank, Exhaust is near dead, headliner is sagging, heater core is leaking and needs winter tires) I remember one person saying it is a $10,000 car...no matter how you look at it....buy one for 10K in perfect shape, buy one for $3K that needs 7K in repairs....it all ends up the same!
    Nov 2004
    Split, Croatia
    Quote Originally Posted by Guelphguy
    It sure looks like it! Well, look on the bright side - if some one sticks a banana up our exhaust at least it won't do any damage - I bet it wouldn't obstruct the airflow one bit from all the holes in it!
    Default Yes, I believe the 10K rule
    still applies. As the car gets older it needs the same attention as when it was new. You probably need a rear axle support and not the carrier?
    One of these?
    You can probably pick some up from this forum, it needs to be done weather you keep the car or sell it...exception if you part it out.
    Nov 2004
    Split, Croatia
    One of these?
    I already swapped out the support! Same thing! And the same support looks OK on another E34, so it can be only one thing - the carrier. Or am I missing something?
  1. M50 525 no start story - its my story and I'm sticking to it!
    Last Post: 01-07-2007, 11:36 PM
  2. QLD guys, what's the story?
    By GJPinAU in forum 5 Series BMW
    Last Post: 01-22-2006, 04:07 PM
  3. check this story out
    By Paul in NZ in forum 5 Series BMW
    Last Post: 10-25-2005, 10:28 PM
  4. Story
    By LMC in forum 5 Series BMW
    Last Post: 04-24-2005, 12:53 PM
  5. My little bimmer story
    By ve39 in forum 5 Series BMW
    Last Post: 03-02-2005, 03:01 AM
