Results 1 to 8 of 8
Thread: What can cause judder when backing up on a slight grade?
    Aug 2004
    VA
    Default What can cause judder when backing up on a slight grade?
    My 1995 525iT is acting strange when I put it in reverse and begin to back up, especially on a slight grade. When backing up, the rear of the vehicle vibrates/judders, like the wheels are losing traction and bouncing. The car has 150,000 miles on it. I replaced all 4 struts on the car, but that didn't fix it. Any idea what might be causing this problem?
    Bay Area, CA
    Mine does that too sometimes.
    www.KaRealtySF.com
    Aug 2004
    VA
    Have you figured out what's causing the problem?
    Bay Area, CA
    nope.
    www.KaRealtySF.com
    Nov 2004
    Middle England
    Sounds very similar to a Ford I had some years ago - turned out to be the handbrake shoes were simply adjusted too close to the drums and the mechanism allowed the shoes to 'grab' the drum when in reverse, in the manner of a real 'sprag-clutch' ... so maybe check handbrake ?
    ... but then again that was Ford engineering ... hmmm
    '90 535iSE Auto (AE+EAT) 123k miles
    '86 F288 69k miles
    '06('89)- PGE 2.0DOHC Turbo
    '03 A160LE 19k miles
    1914 Stellite E2A (no odometer!)
    (+ others I daren't mention here)
    www.pyghtle.com
    Aug 2004
    VA
    Quote Originally Posted by zygoteer
    Interesting thought. This car has rear disc brakes and not drum brakes. Could this still be an issue?
    Nov 2004
    Middle England
    Quote Originally Posted by atomicDog
    Well my E34 535i SE has drum brakes in the middle of the rear discs exclusively for the handbrake function.
    I had no idea the 525iT was different in this respect, as I thought all E34's were the same layout etc.
    '86 F288 69k miles
    www.pyghtle.com
    Mar 2004
    MASS
    Default Check the center drive shaft bearing
    Grab the drive shaft and see if it's loose on the bearing. That's after checking the emergency brake pads.
  1. Rear brake backing plates - easy to R&R?
    Last Post: 01-03-2010, 11:31 PM
  2. Judder/Loss of power
    By e34.535i.sport in forum 3 Series BMW
    Last Post: 10-04-2007, 07:39 PM
  3. Replies: 12
    Last Post: 12-23-2006, 09:46 PM
  4. e34 brake judder
    By colin jenkins in forum 5 Series BMW
    Last Post: 04-19-2005, 09:55 AM
  5. Clutch judder in 1st
    By tinkerscorner in forum 5 Series BMW
    Last Post: 03-18-2005, 05:21 PM
