Results 1 to 2 of 2
Thread: coolant expansion tank o-ring and level sensor proc.
    Austin, TX
    Default coolant expansion tank o-ring and level sensor proc.
    Anyone explain how to separate that tank from the radiator, and what silicon if any i should use?
    Gary M Guest
    Default Re: coolant expansion tank o-ring and level sensor proc.
    Take out the air bleeder screw. Remove the radiator cap. Take out the allen screw. Remove the top black plastic cover. Pry up the expansion tank. The sensor doesn't come out with tank. It's underneath it and you need to remove the connector wires and the nut that holds it in and pull it straight down. Good luck it's a bitch to get a wrench in the enclosed area.
  1. A bit oil in coolant expansion tank. Time to worry?
    By mitch2k in forum 5 Series BMW
    Last Post: 09-24-2006, 06:24 AM
  2. Tank level sensor
    Last Post: 09-09-2005, 01:00 AM
  3. replace coolant expansion tank
    Last Post: 06-23-2004, 01:34 PM
  4. SLOW leak at bottom of Coolant Expansion tank :(
    By MO525 in forum 5 Series BMW
    Last Post: 03-08-2004, 11:57 PM
  5. anyone replaced the coolant expansion tank o-ring?
    By bimmerd00d in forum 5 Series BMW
    Last Post: 02-29-2004, 06:02 PM
