Results 1 to 8 of 8
Thread: Power window/sunroof upgrade?
    Wichita KS
    Window regulator is the mechanism that raises and lowers the window. For power windows it has the electric motor attached, not sure if you could put the electric motor into a manual ragulator, you may have to get the whole thing. But if you do your shopping at wrecking yards, that's what you will get anyway, the whole regulator.
    BTW when replacing a regulator, use rubber door stops to hold the glass up while you pull the regulator out and slip in the new one.
    Philippines
    Ok! Thanks!
  1. Sunroof upgrade?
    Last Post: 05-24-2008, 12:58 AM
  2. Brake light, sunroof, doorlock and window problem
    By rosiebimmer in forum 5 Series BMW
    Last Post: 05-20-2006, 06:54 AM
  3. Replies: 2
    Last Post: 12-01-2004, 02:58 PM
  4. Power Window Won't Go Up
    By Chrissi in forum 5 Series BMW
    Last Post: 10-07-2004, 06:34 PM
  5. 318i all doors and sunroof power is not working
    By prosssopheap in forum 3 Series BMW
    Last Post: 07-26-2004, 12:33 PM
