Results 1 to 9 of 9
Thread: 525i (m50) transmission oil cooler
    Bay Area, CA
    Default 525i (m50) transmission oil cooler
    my car had an inspection II done to it today. they found a leak and said it's related to the tranny oil cooler. they are unsure at this point if it's just the o-rings or whether it is the tranny oil cooler itself. that's the probability that it is the oil cooler? how long do these thing usually last? my car has 145k miles on it. TIA.
    Aug 2004
    When i had my transmition oil changed my leak stoped
    if you didn't have tranny oil change for more then a year i suggest you do
    Bay Area, CA
    i get a tranny flush during every inspection II. so that was done.
    they said they're going to clean up the area, drive it for a few miles, and see what's up.
    Bay Area, CA
    Bay Area, CA
    bad news... leak seems to be coming from the cooler itself. %@&#!!!
    PA
    Quote Originally Posted by shragon
    I have an oil cooler your could probably use rob... here's an image.
    Bay Area, CA
    thanks for the offer jon! the shop aleady has one coming in tomorrow. i do appreciate it though!
    Benneton (United Colors of)
    you do realise that many, many of the flush machines (i would guess most of them) hook up to the atf pipes that would normally be attached to the cooler? perhaps the orings died when the pipes got taken off.
    Bay Area, CA
    o-ring area was checked, and it was fine.
  1. Replies: 13
    Last Post: 01-21-2011, 07:55 AM
  2. Replies: 7
    Last Post: 06-24-2008, 08:23 PM
  3. Replies: 1
    Last Post: 05-02-2008, 05:32 PM
  4. Custom transmission oil cooler question.
    By danielhstout in forum 5 Series BMW
    Last Post: 12-15-2006, 07:52 PM
  5. transmission oil cooler
    By Phil M in forum 5 Series BMW
    Last Post: 07-30-2004, 01:56 AM
