Results 1 to 9 of 9
Thread: Gas gauge
    Hockinson, Washington
    Default Gas gauge
    My tank showed a little over 1/4 tank, so i stopped at a shell station and put $40 v-power in. I start the car and drive away. The gas gauge sitll says its at 1/4 tank. It worked when i got it, is it now stuck? Is it a problem with the gauges or the actual sensor? How can i find out?
    Honolulu
    Default What does the range function on th OBC say?
    If it's @400 miles, then maybe the guage is stuck, since the OBC also reads the sender.
    Sep 2005
    NJ
    My gauge is also a little quirky. Sometimes I will start the car and it will say I have about a half of a tank, and I'm like what??? I just filled it up yesterday. It will then slowly go back to full after about 10 minutes of driving. Sometimes it will display more fuel than what I really have in the tank. It's not that bad, Im pretty sure it's just a sensor, not the actual gauge.
    Run the dash module self test procedure (do a search on it for the specifics), that should confirm gauge operation.
    The sender has a float in it. The sender can crack, or (in a case I saw yesterday) the float can get stuck -- ie, half way down, such that you think the car has a half tank of gas yet it's completely empty. Rust belt cars can also be susceptible to having the leads corrode (pull the access panel and have a look).
    Probably just the sender, though.
    best, whit
    Ugh...the obc seems to be getting the same information that the gauge is, how much is a sender?
    Long Beach, CA
    Shogun had a pretty good post on this issue (Or very close) last week. You might want to do a search.
    Honolulu
    Default You may be able to fix the sender
    Sometimes the sender float is being interupted by the casing, or the resistor wire are dirty.
    I'd take it out and look at it first.
    http://shrubbery.student.utwente.nl/...el_sender.html
    Check this site out
    Long Beach, CA
    Quote Originally Posted by Blitzkrieg Bob
    Check this site out
    That's the link I was talking about!
    Honolulu
    Default You gotta put Shogun's page
    into your favorites...He got a load of stuff (some in other languages) that's very helpful
  1. Gas Gauge Does Not Work!!!!!!!!!! On My 89 E34
    By frankthetankjfpc in forum 5 Series BMW
    Last Post: 05-24-2008, 12:10 PM
  2. New Car (Gas Gauge Broke)
    By indymdm in forum 5 Series BMW
    Last Post: 12-14-2006, 11:22 PM
  3. vdo gauge panel
    By tim in forum 5 Series BMW
    Last Post: 01-10-2006, 05:56 PM
  4. how do you like my new gas gauge?
    By billb in forum 3 Series BMW
    Last Post: 12-16-2005, 07:24 AM
  5. mph gauge
    By 1000_eyez in forum 5 Series BMW
    Last Post: 11-06-2004, 01:27 PM
