Results 1 to 10 of 10
Thread: 750il 3.15 LSD available
    Jun 2005
    Davis, CA
    Default 750il 3.15 LSD available
    I was at the local pick your part today. There was a 750il with 3.15 lsd final drive in it. I'd love to have it myself but the input flange is different than on my 535i. Has anyone looked into swapping driveshaft CV joints to use the 750il final drive on a 535i?
    My car has a 3.91 open would like to find a 3.46 open or preferably lsd. Anyone have such a beast?
    Craig in Davis
    89 535i auto to manual conversion
    Delphin-Metallic/Black leather 296k
    83 533i 5 speed Alpinweiss/Cardinal Red leather 236k
    750 is too big, wont fit.
    Why would you want to get a shorter gear anyways? Looking for less mpg and performance or something?
    SCHUYLKILL COUNTY, PA.
    Default how much for the 750 lsd???
    Quote Originally Posted by Craig in Davis
    thanks
    tim s.
    Yes, why the heck would you want a 3.15 in a 535 manual?
    Like Jeff said....the housing is completely different, especially if it's an E38.
    best, whit
    Jun 2005
    Davis, CA
    Quote Originally Posted by lowell
    best, whit
    Well, I'd really like to find a 3.46 to go to stock manual setup. I do mostly highway driving when I drive so would like to bring the rpms down and the mpg up. 3.15 is admittedly a little too low. Temporary bit of insanity due to rising fuel prices I suppose.
    Craig in Davis
    Jun 2005
    Davis, CA
    Quote Originally Posted by tim s
    thanks
    tim s.
    Tim,
    Are you anywhere near Sacramento, CA? Shipping would be pretty pricey.
    Craig in Davis
    Craig, I want to amend the statement I made yesterday about the E32 diff housing. It will fit -- the carrier points are the same -- but the flanges will need to be changed, and there's the potential that the axles won't fit because the unit itself is bigger. The input flange may also be an issue, but as I think you have an adjustable driveshaft, you might be able to get away with it.
    No doubt it would be an interesting swap with some of its own issues to ponder. I still think a 3.15 would be a bad compromise with anything that wasn't freeway driving.
    best, whit
    plus add in the assneck factor and you get to do this.
    http://www.bimmer.info/~regal632/rearend.html
    Jun 2005
    Davis, CA
    best, whit
    If someone on the board wants the diff for there V8 based e34 let me know.
    Based on reading the MPG thread and looking up EPA figures for 89 535i, I may actually be doing pretty good. My OBC tells me 23.3 for ~200 mile trip freeway driving at 65 mph some A/C. EPA is 15/23 for an 89 535i manual. I'll see what the actual mpg is at the next fillup.
    Interestingly, I have 3 m30 based 5 series BMW's, they all get between 22 and 25 mpg highway and have vastly different weights, etc.
    Craig in Davis
    ...and <vastly> improved fuel injection systems, chronologically speaking
    23 is about what I get when cruising on the highway.
    best, whit
  1. Problem on 96 750iL Help pls!!
    By Stolichnaya in forum 7 Series BMW
    Last Post: 02-09-2008, 09:39 PM
  2. my E32 750iL pic series
    Last Post: 05-24-2007, 08:23 AM
  3. anyone needs E32 750iL parts in NZ/AUS?
    Last Post: 04-24-2006, 09:55 PM
  4. Help, my e32 750iL is beeping at me.
    By JimProfit in forum 7 Series BMW
    Last Post: 09-20-2005, 06:29 AM
  5. E32 750iL used car review
    Last Post: 08-05-2005, 07:34 AM
