the size of tire is irrelevant, the sticker is accurate for the car, regardless of size... 15", 17"...
pressure per square inch is the same
congrats on the wheels
Hey Guys.
I got my hands on a set of "Style 5" rims (the ultimate wet dream rims!).
17 inch, 235 wide. From an E39 w/hubcentric rings.
What I need is some info on the "correct" pressure for the tires. The thingy inside the driver's door doesn't give any info on that width of tire.
Suggestions?
^°^ ><((({º>°°
Congrats! But now you will need to find a good wheel cleaning product, buy shares in the company and watch your stock rise!!Originally Posted by NielsGalan
I agree 100% that the correct pressure is what is on the door jamb sticker.
BUT
With lower profile tires, running the same pressre can lead to rim damage as less deflection is required to make contact with the rim. Which is why many people with +2/+3 wheel/tire packages run higher pressures.
Also, higher pressures will affect handling. You can dial down understeer, increase cornering speeds by playing with tire pressures.
FWIW I run 38 psi all around on 225/55/16 Bridgestone SO3s.
M5 spec is 38F/41R for normal driving. This is for a 235/45ZR17 tire.
The spec for the 225/60HR15 is 29 front IIRC - way too low for a lower profile donut.
Anthony
03/64 production
Tire pressures given for E34 M5 with 235-45-17 tires are 38 front 41 rear. This should put you about right. You can plus or minus 2 psi and see if you like the difference.
Congratulations on the wheels, you'll soon see that there are 34 little titanium bolts that hold the two piece wheel together....=) just ask me how I know...
But what's the torque sequence?Originally Posted by Jr ///M5
Anthony
03/64 production
same as always,the star pattern but with 34 points...now keep track of which is which!!!!I am gonna try the M5 pressures too!
Gone but not forgotten
I run 41 all around on my 5's and have never had any rim damage (or sidewall damage)...a little bit of oversteer, but I think that's a chipped 4.0L V-8 and 6-speed for ya!
Cheers,
Duey
So where are the pictures of your car with the new wheels?Originally Posted by NielsGalan
