Results 1 to 10 of 22
Thread: Warming up your engine
    Default I disagree, its not that nothing bad happens from letting it idle to
    warm up, its that it increases wear. The manufacturers all advise you to drive away shortly after starting to promote rapid warmup, It warms up quicker this way and the parts expand to the proper tolerances faster, reducing wear. If an engine sits and idles to warmup it takes longer to get warmed up to operating temperature. The greatest amount of wear on any engine is during the starting and warmup period, so by driving it at a moderate pace, you warm up the engine much quicker.
    Quote Originally Posted by Robin-535im
    Nothing bad happens (aside from "wasting" gas) from letting your car warm up at idle. Nothing.
    I say "wasting" because it's a teeny bit of gas relative to how much it takes to actually move your car down the road.
    Bad MIGHT happen if you let it warm up at idle until the water temp indicator says it's warm, then flog the hell out of it... but the point is that "water temp warm" and "engine and drivetrain at operating temp" are different things.
    What you want is for the drivetrain to be at operating temp before you stress it, where stressing it is applying large loads (flooring it or going high-speeds, EITHER RPM or MPH)).
    You could warm the car with a heating blanket. You could park your car in an oven. You could let it idle - but idle doesn't heat up the gear boxes so if you let it idle to warm up, the whole drivetrain is not ready for flogging.
    Car manuals are written for simplicity and clarity... the easiest and safest way to describe warming up is not to go into the details of operating temps of the gear box etc. etc., but just to say "Idle - bad. Drive - Good!"
    Just had to get that off my chest. Wheew. Feel better now.
    - Robin
    Well - we can agree to disagree... by your logic we should all redline the car immediately upon starting so we can warm it up as quickly as possible?
    Driving will place a load on the car, and a loaded car suffers more wear. Alternately, like you said, time spent at a sub-optimal operating temperature causes wear. I will defer to the engine manufacturers if they say that the latter outweighs the former in some cases, but not all.
    We know that the M5 rev limiter goes up as the engine reaches operating temp. That says that at some level, loading the engine when cold is bad. Where is the real cutoff? Should you: a) let the car idle at 800 RPM, b) putter around at 2000 (probably yes) or c) really heat it up fast by running it at 6000?
    Point is there are conflicting effects here, and the truth is not so simple as "warming at idle is bad." Is it sub-optimal? Probably. Can you do a lot more harm by high revving your cold car than by letting is sit at idle? You bet. Can we ever really answer this problem without a test that accounts for all the factors? No. Is this my Donald Rumsfeld impression? Sure is.
    All driving does to warm the engine faster is to rev it more - the motion doesn't make the car warmer, in fact the motion adds cooling via air passage, unless you live in one of those places where the ambient air is over 100!
    I'm not promoting letting the car idle until full warm, but I think it's wrong to scare people into driving off immediately instead of letting it idle for a minute or two if they want. In fact, I maintain it's better to idle for a minute and then drive normally than to simply start the car and drive normally, if "normally" means you drive like most of us do: with enthusiasm!.
    Bottom line is that it's way more complicated than can be summarized by "warming at idle is bad", and the differential wear of warming at 800 RPM vs. warming at 800 - 2000 RPM is (I believe) negligable compared to the wear caused by running at high RPM's (which we all do), letting the oil sit unchanged for the complete BMW_recommended service interval (which heaven forbid any of us do) or having a sensor or part out of spec. To worry about warming the car at idle is like polishing the brass on the titanic, if I can borrow a quotation from Fight Club.
    But - I welcome disagreement!!
    - Robin
    Robin
    72 Chevy K10
    01 E39 M5
    Melbourne, Australia
    Well - we can agree to disagree... by your logic we should all redline the car immediately upon starting so we can warm it up as quickly as possible? ...
    I didn't notice that Bill suggested to redline the car when cold.
    Moderate smooth driving is all that is required for the first few minures.
    Driving will place a load on the car, and a loaded car suffers more wear. Alternately, like you said, time spent at a sub-optimal operating temperature causes wear. I will defer to the engine manufacturers if they say that the latter outweighs the former in some cases, but not all...
    Warm up time requirements have tended to change over the years for a number of reasons. There were (in some cases still are) valid reasons for allowing an engine to 'warm up' before driving off. For instance many older carburettor fitted engines would often hesitate and sometimes stall until a certain operating temperature was reached. Nothing worse than pulling out into a break in the traffic to find your 'cold' motor has suddenly cut out and a semi is bearing down on you! Not so with most fuel modern injected motors. They should run reliably, without risk of cold stalling, right from startup. Also older (thicker at low temperatures) non-synthetic oils don't flow as well as modern multigrade (synthetic) oils and could often take sometime to pump through to all areas of the engine. With oil grades now commonly starting around 0w, 5, or 10w the oil flows much more quickly to all parts of the engine at low temps so the risk of oil starvation, and associated wear caused by 'thick cold oil' is greatly reduced...
    We know that the M5 rev limiter goes up as the engine reaches operating temp. That says that at some level, loading the engine when cold is bad. Where is the real cutoff? Should you: a) let the car idle at 800 RPM, b) putter around at 2000 (probably yes) or c) really heat it up fast by running it at 6000? Point is there are conflicting effects here, and the truth is not so simple as "warming at idle is bad." Is it sub-optimal? Probably. Can you do a lot more harm by high revving your cold car than by letting is sit at idle? You bet. Can we ever really answer this problem without a test that accounts for all the factors? No. Is this my Donald Rumsfeld impression? Sure is...
    I don't think anyone is suggesting that running an engine at excessive revs (above say 4000 etc) when cold is a good thing. Potential (cold) oil starvation has already been mentioned. However letting it sit idling for ten minutes is not the best option either, option b) is the most sensible.
    All driving does to warm the engine faster is to rev it more - the motion doesn't make the car warmer, in fact the motion adds cooling via air passage, unless you live in one of those places where the ambient air is over 100!..
    Air flow through the radiator of a cold engine has negible cooling effect until the thermostat opens and allows coolant flow.... unless of course your thermostat is stuck open or has been removed.
    I'm not promoting letting the car idle until full warm, but I think it's wrong to scare people into driving off immediately instead of letting it idle for a minute or two if they want. In fact, I maintain it's better to idle for a minute and then drive normally than to simply start the car and drive normally, if "normally" means you drive like most of us do: with enthusiasm!...
    I would think that in reality many people will often run the engine for a minute or two before they drive off even if they say they don't 'warm' it up. This is especially true at first start up in the morning. From my own perspective I wouldn't say I warm my car up but I get in, start the engine, turn on the radio, adjust the volume, put on my seatbelt, check my mirrors, reverse back around to the side of of the house then forward up my drive and out into the street. I don't get out of 2nd gear or even to 2000rpm's until maybe two minutes after first start up so I guess you could almost say this is my 'warm up' period, even though I'm actually travelling somewhere while it's warming up.
    - Robin
    I think the validity of an extended idle warm up periods with modern engines and lubricants is a thing of the past, and offers no real benefit in terms of engine wear or longevity compared with a sensible 'start and drive off' approach. Granted extreme revs or engine loading when cold is not a good idea, but remember that engines are designed to spend the majority of their life at operating temperature and those engines that last the longest (ie. taxis etc) spend most of their life running at optimal operating temperatures, and any automotive engineer will tell you the longer an engine spends running at sub-optimal operating temperatures the greater the engine wear.
    I just think the fear of letting a car idle a bit is silly.
    Quote Originally Posted by pundit
    Being facetious of course... but if "warming it up the fastest" is the primary metric of engine health, stands to reason that bouncing it off the rev limiter will be the optimal solution!
    Robin
    72 Chevy K10
    01 E39 M5
    I just think the fear of letting a car idle a bit is silly...
    I'm not sure I get your point? Who's in fear here? If there was a benefit in an extended idle warm up period then I'd say by all means... "Start engine, let idle for five or ten minutes, then drive away!"
    I gather your motivation for starting this thread was a belief in a starting (warm up) method that was the most beneficial ie. least harmful to your engine. I think we all want what's best for our engines... don't we?!! I don't disagree at all about avoiding excessive revs, or loading on a cold engine.
    Traditionally the school of thought has been to always start your engine and let it warm up for a few minutes before driving off. In fact a friend of mine used to start his car, go back inside the house, have a coffee and then come back out and drive off. He owned a 1964 EH Holden Premier 179. (Most Aussies will know what I'm talking about here!) This old school of thought was, back then, often quite a valid one. Unlike modern oils, the time taken for the oil to reach all parts of the engine at first start up would have taken longer than with modern lubricants, hence not a good idea to rev the hell out of the engine at this point. Also was the problem of fuel not vaporising properly and condensing inside the walls on the inlet manifold of a cold carburettored engine. Having the choke at three quarters whilst pumping the accelerator like hell to ensure enough fuel got into the cylinders tends to dilute the oil film on the cylinders walls reducing the lubricating effect, also increasing wear. These two things alone could definatley accelerate engine wear if one simply drove off with a stone cold motor, like a lunatic at high revs, pumping the accelerator like and before the bearings had received enough lubrication.
    The two main causes of engine wear at initial start up are greatly reduced in vehicles fitted with correctly operating fuel injection systems and modern free flowing oils compared to the 'norm' of say 30 years ago or more. So if cold starting lubrication and oil dilution problems are now much less of an issue, which they are, then more benefit will be gained by a sensible 'start and drive' approach than a 'sit and idle' approach. Besides in the five minutes I'd waste letting the engine idle, I could have driven 5kms (3 miles) that's say twenty times in total per week. So in the time I was sitting waiting for my engine to 'warm up' each week I could have driven 60miles while it was warming up!
    Well if I applied that logic elsewhere I should be able to consume half a ton of viagra and become the biggest stud on the planet!
    I think that's where I lost you... you were assuming I had a point??
    You are spot on my friend. I agree with all of it. In fact, I don't think I ever said it was a good idea to let it idle, just that it wasn't really a problem to let it idle a minute or two.
    Geez - I seem to recall some post a while back where someone was really opposed to letting it idle at all, and I thought, "well, that's silly - there are worse things you can do."
    In fact, it's so not worth worrying about that I feel guilty for typing so much in this thread! Bring on the weekend!!
    BTW - someone really needs to take some data on how long it takes to warm up the engine water and oil at different RPM levels. That would be interesting to see.
    And I think I'll try that viagra thing you were talking about...
    - Robin
    Robin
    72 Chevy K10
    01 E39 M5
    Perth, Australia
    i let mine idle until i see the needle has moved off zero.. then i just drive under 2.5k rpm until it hits halfway, then it flog it!
    i never just start a car when stone cold and drive it, after driving an old carburetted 4 cylinder toyota you learn not to do things like that..
    Aug 2005
    Toronto
    Toronto police will give you a ticket if they catch you idling more than three minutes.
  1. problem warming up in the morning
    By e34m30SF in forum 5 Series BMW
    Last Post: 02-22-2008, 12:17 AM
  2. Replies: 42
    Last Post: 12-06-2006, 05:16 AM
  3. Replies: 6
    Last Post: 10-10-2004, 03:49 PM
