Results 1 to 5 of 5
Thread: Check oil level light?
    Jun 2005
    Nashville, TN
    Default Check oil level light?
    I keep getting a check oil level light but my level is fine. This happens once every 5-6 days or so. I keep checking my dipstick and it is perfect level wise. Do I need to do something or should I just d=shrug it off for now. Oh yeah I have a 95 525I Auto.
    Jul 2005
    Cologne, Germany
    a light?
    should be a message which appears in your Check Control display...
    greets from Germany,
    Kai
    A BMW is a black car with most rights in road traffic.
    Honolulu
    Default Check the plug to the sensor
    it's low on the engine block and it gets mucked up.
    Gently try to separate to the plug and clean the contacts with a electronic contact cleaner.
    Beware the plastic plug body for the sensor may disintergrate in your hand, like mine did.
    If so...
    Reply back and I will walk you through a fix.
    Jun 2005
    Nashville, TN
    Quote Originally Posted by Kai@e34.de
    a light?
    Thats what I meant, I just had to many Brews at the mexican restaurant. Anyways I'll try to clean the plug first and see if that works. Can I reach that plug from the top of the engine?
    Honolulu
    Default The plug is down low on the block at the oil pan
    get under the car and look at the front driver's side of the oil pan for the sensor line and plug. it's usually a red colored line with the a three contact Bosch type plug.
  1. transmission fluid level check procedure
    Last Post: 10-29-2011, 06:11 AM
  2. How to Check Trans fluid level
    By Rumblecloud in forum 5 Series BMW
    Last Post: 11-18-2005, 10:26 AM
  3. Proper way to check oil level?
    Last Post: 03-02-2005, 04:12 PM
  4. How to check ATF level?
    By Matias in forum 5 Series BMW
    Last Post: 06-09-2004, 06:56 PM
  5. Engine on or off to check auto trans fluid level
    By Robert K in forum 5 Series BMW
    Last Post: 04-04-2004, 06:32 AM
