If it coming from the wheels or from under the hood drivers side.
Then you can determine what is the cause.
Do your parents know you've got the car?
I think there may have been a thread on this issue before but I am having difficulty locating it...
so when I push the brakes harder than I normally would...I hear this whine, it goes away once I start accelerating...but it is bothersome nonetheless.
what could this be? is there an easy solution?
1989 535i 155k Miles
does it kinda seem like it could be the tires but not able to pinpoint the area? I have the same issue, perhaps its the engine mounts when the engine is forced forward it gets worse?
Sounds like the same problem I noted on pop's '90 535iM. Is your noise worse when the engine is cold? I suspect it's something with the steering pump because the whine changes pitch if I turn the steering wheel. Perhaps a PS fluid flush is in order.
Anthony
03/64 production
i have the same thing in my e34 and had it in the e32 i think its normal or both of my cars are and were fuc#ed
okay, thats the answer I was looking for...
"i think its normal"
Thanks for the piece of mind.
It's not "normal" 'cuz the 535 didn't do it when I owned it but started to do it recently. ~250,000kms on it now.Originally Posted by 632 Regal
Anthony
03/64 production
yeah its the loudest when I just start the car in the mornings...and yeah it does make strange noises when I move the steering wheel
have you changes the power steering fluid? Is it full?
Originally Posted by beamerman5
i have not touched it...that is probably the problem...ill check it out in the morning
