Results 1 to 10 of 11
Thread: Tank level sensor
    Aug 2005
    Default Tank level sensor
    Here is a link to a fuel level sensor being sold in Ebay.
    http://cgi.ebay.com/ebaymotors/BMW-F...temZ7994427325
    I have a 1994 BMW 520 (E34) with M50 engine and plastic tank. Will that fuel level fit my car?
    The fuel level sensor on my car is fixed with a large plastic "nut". You have to screw out and it comes out (I did not open it).
    Thanks in advance.
    Try out the online spare parts catalog.
    With used parts you have to know what you buy, so better check carefully.
    Aug 2005
    can you give me a link to one of those spare parts online cotalogs?
    Tampa Bay, Florida, USA
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Elm Grove Farm, NC
    www.realoem.com is good- it's basically the BMW ETK (electronic parts catalog) with some imaginary prices (the site says they are not yet selling parts- not sure what the prices are based on......).
    One useful feature is the "find part number" link- once you find the part number you need, you can enter it and it will tell you what other models that part number can be found on...
    Bret.
    Or take the BMW PartLookup. That has the advantage that the drawings can be copied and shown here on the board, whereas with realoem you can only link that one
    http://www.bmwtoolkit.com/index.php?...tpage&Itemid=1
    If you have a 1994 520 M50 with plastik tank, then you should have the European version
    Additional info;
    Just see that the vendor is vinesauto. They are quite experienced. Send email to the vendor and ask them if it fits to your car. Best is you give the the chassis number.
    Australia
    no, it will not fit. I've been down that path before. there is a different sensor for the plastic tanks.
    Aug 2005
    i just looked up in the www.bmwtoolkit.com website and yes, this fuel sending unit will not fit my car. Its for a car with metal tank. A really great site guys.
    The fuel sending unit in my car usually does not show anything, but if you fill the tank it shows something like 30-40% full tank. Is it possible to repair that? Why is it showing wrong?
    I had another second hand BMW 5 series (don't know exact number) with plastic tank like mine. Its fuel level senso was also showing wrong levels. With 10 litres it was showing nill.
    Honolulu
    Default BMW over Engineered
    Most of the car..So as I have found, most fixes are possible.
    If the sender is still working through some of the range of the gauge, than you may be able to pull the sender and fix it by either cleaning the resistor wires or re mounting a losse sender cover that maybe interrupting the floater.
    Order the gasket and give it a try
  1. oil level sensor
    Last Post: 05-10-2013, 07:13 PM
  2. Q: Oil Level Sensor
    By BMWDriver in forum 5 Series BMW
    Last Post: 08-17-2009, 09:48 PM
  3. Is this the right Oil Level Sender/Sensor?
    By ElNormo in forum 5 Series BMW
    Last Post: 06-10-2006, 10:42 PM
  4. Oil Level sensor
    By PatrickPGH in forum 5 Series BMW
    Last Post: 10-29-2004, 12:59 PM
  5. coolant expansion tank o-ring and level sensor proc.
    By bimmerd00d in forum 5 Series BMW
    Last Post: 03-02-2004, 12:24 AM
