Thread: Choosing Wheels
    Jul 2005
    Washington State
    Default Choosing Wheels
    Hey guys I am looking for some advise. my car is a 1994 525i and I am looking to go to 17" wheels and tires. I like the looks of the Beyern but they only come in 15mm offset, and my car uses a 20mm offset. is the 5mm differance going to make a real bid differance in handleing and ride?
    thanks
    Chris
    Python1
    1994 525i
    no, you will be 'aight.
    Aug 2005
    Toronto
    5mm is nothin'
    Just to be sure, before buying the wider wheels, you'll want to check the clearance between the tire sidewall and the strut. Tires wider than ~225mm may rub the strut.
    I put wider basketweaves from a '95 740il on my '90 535i, and whereas the wheel offset was OK, the wider/fatter tires rubbed.
    Quote Originally Posted by python1
    thanks
    Chris
    The Beyern line is from TSW, and will fit just fine. Personally, I'm not a big fan of the styling, but to each his own. Since they are 8" wide, I don't recommend a tire wider than 235mm (235/45-17 is perfect) I also have these http://www.discounttiredirect.com/pr...vkra.sm.xl.jpg available if you care in 17x8" +15 for $160 delivered brand new in the box
    1995 540iM Alpine White/ Lt Silver Grey 84k
    1992 535iM Black/Lt Silver Grey 132k
    1990 535iM Glacier Blue/Blue 206k
    Jul 2005
    Washington State
    Thanks alot guys, I purchased a set of wheels and Tires as follows:
    Beyern type Mesh 17"x8" +15 and Toyo Proxes 235/45-17 they fit and look great. I now just have to sort out a vibration that starts at 50 and get worse by 55 mph and then gets a bit better by 60mph.
    Python1
    1994 525i
  1. WHEELS! NY/Proximity plz read! Snatch up these wheels!
    Last Post: 09-11-2006, 05:46 PM
  2. How much should I ask for these wheels?
    By horseheadnebula in forum 5 Series BMW
    Last Post: 09-09-2006, 11:41 PM
  3. Looking for wheels for my 91 535
    By maaweb in forum 5 Series BMW
    Last Post: 08-13-2006, 06:09 PM
