the other day the guage was in the red (all the way right) and the heater wouldn't help cool it down. i figured that it was the thermostat so i inspected it and it was opperating normaly in hot water (is ~6months old). i then reinstalled it and started it up. while bleeding it, it took it's time getting up to operating temp (...normal amount of time with the heat on). once at the operating temp i sat there and watched it. everything seemed normal then it bounced up to the next line up and then back to normal with in about 3 seconds. it did that probably 3 times within 5 mins.
then it jumped to full hot so i shut the car off and turned the car back on (engine off) and the guage still read full hot. i then shut it off again and turned it back on and the gauge read normal. all this with in 10-15secs. max
i tested the sensor and it tested ok, but i'm thinking that the sensor is on it's way out. that's the only thing i can think of, unless there's something else that can cause coolant temp changes so rapidly.
what do you think?
