Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Finished the auto to manual swap 535i
    Long Beach, CA
    And done for around $840.00 (If I did my math correctly) + your time. Well Done!
    Jun 2005
    Davis, CA
    Quote Originally Posted by uscharalph
    Actually, it was $803.01 the other cost were $41.04 for 2 new trunk struts, $146 for DMV registration (it was slightly overdue), and $300 purchase.
    Craig
    Craig in Davis
    89 535i auto to manual conversion
    Delphin-Metallic/Black leather 296k
    83 533i 5 speed Alpinweiss/Cardinal Red leather 236k
    Jul 2005
    North SF bay area Delta region
    Quote Originally Posted by Craig in Davis
    Yes, I am in Davis, CA
    Yes, I go to the import yard frequently. I was there last Monday; I think there are 2 1/2 rows of BMW/Mercedes cars. The BMW's are a mix of e12, e28, e23 e21 and e30. There are occasionally others but that is pretty much what I have seen. I have only seen 2 e34's at the yard and they were both roll over type accidents so much of the car was toast. Unfortunately, they were there a few weeks before I got my car but gone when I went back to check for parts.
    Any e34s?
    It seems to work ok though could be a little colder. Maybe it needs a little bit more R134a.
    Craig
    Small world ain't it !!
    I think Pick n Pull sells off the premium Bimmers to places like Bavarian in Ranhco Cordova, as I rarely see them.
    I saw one E34 each in the Oakland and Richmond yards and they were pretty chewed up and picked clean of most good parts. The one I saw at Oakland wasn't even in the BMW section.
    Your AC could be over filled too . The retrofit uses less refridgerant than what the R12 system called for. But it would be hard to say without hooking up the gauges.
    The BMW retrofit kit includes a different low pressure switch ,to kick in the compessor sooner. At least that is what I was told.
    Chris
    1991 525i M50 5 Sp.
    N.California
    Jan 2005
    what clutch did you use with the e-12 flywheel?
    Jun 2005
    Davis, CA
    Quote Originally Posted by duckloads
    E12 flywheel, clutch, throw out, and transmission.
    Craig in Davis
    How long did this project take Craig? Sounds like an awful lot of dedication went into it.
    Jun 2005
    Davis, CA
    Well, I bought the car on 22 May 2005. I bought the pedal assembly, interior shift pieces, hydraulics 3 June. I went to the junkyard and pulled the tranny, flywheel on 14 June. Probably within a week or two I had removed the last remnants of the automatic and installed the flywheel, clutch and tranny. This is when I hit a roadblock. The shift linkage from the E12 was too short for the E34. I was looking into finding a linkage the correct length but really wasn't trying very hard. So from say the end of June until close to the end of August nothing happened. Then toward the end of August my neighbor asked me about the project and offered to modifiy the linkage for me. After my neighbor helped with the linkage it was all together in another few weeks including 3 days for driveshaft modification/repairs.
    So, a little over 3 months from purchase to running car. However, it really took less than a month of working on it part time if you take into account 2 months of no activity. It is actually a pretty simple job, mostly just a bunch of swapping parts.
    Craig in Davis
  1. help please with wiring on auto to manual swap
    Last Post: 05-01-2008, 11:32 PM
  2. Finished the 535i 5-spd swap . . .
    By gale in forum 5 Series BMW
    Last Post: 02-09-2008, 04:14 PM
  3. 530 auto to manual tranny swap...
    By spyrot1 in forum 5 Series BMW
    Last Post: 02-05-2007, 09:23 PM
  4. Auto to Manual Swap
    By Rory535i in forum 5 Series BMW
    Last Post: 02-25-2005, 12:32 AM
