Originally Posted by
CBC
Thanks for the feedback. I'll stay away from the upgrade...seems like too much work and too many chances for a mistake.
I have been working through a ongoing issue with the air temp at the vents decreasing as I increase fan speed. On speed 1 and 2, I get very comfortable cold air, but on speed 3 it becomes somewhat less cool, and then on speed 4 noticably less cool. I have had all the underhood components replaced and the system has been recharged with 134. I replaced the heater valves with new ones and that did seem to help quite a bit. Two things I am noticing as I observe this problem closer - the air volume from the vents stays the same regardless of my vehicle speed (my other non-BMW cars have more air volume at highway speeds, so this just be a difference with BMW's), and secondly, the compresor (new) seems to cycle on and off frequently - on for 5 or 10 seconds, then off for 5 or 10 seconds. A friend with a 91 525i suggested there was too much freon in the system. The shop that did the repair says it the correct amount is in the there. My firend also recommended the control unit replacement, explaining he had similar A/C problems that were corrected by its replacement.
Any ideas? Thanks
