Originally Posted by
Hal
My wife's 1999 528iT has had intermittent starter problems over the last week, where it sometimes wouldn't start (no crank, no noise, no nothing), but on the next turn of the key, would start right up as usual. It is now dead (i.e. not starting) about 15 miles away. It will not start in Park or Neutral. I am assuming that it is either the ingnition switch, the neutral safety switch, or the starter relay. Everything else in the electrical system seems to work fine.
My E34 (1994 530iT) has a 30A starter relay, so I bought a replacement E39 30A relay (formerly orange, now lime green) at the stealer (open today). I have a Bentley's for the E34 but not for the E39. When I got to the car to swap relays, I discovered that they moved the relay box. I couldn't get the back seat up with the tools that I had with me.
My questions:
Is the starter relay indeed under the back seat, and which relay is it? Is the starter relay formerly orange (30A) and now lime green? The guys at the parts counter only had the same diagrams as realoem.com, which did not identify which relay was the starter relay. Is there any trick to getting the back seat up other than removing the child seat clips then pulling up like an E34?
I promise to order the E39 Bentley's next week.
Hal
1994 530iT 145K (Nikasil)
1999 528iT 85K
