Yes, it is. It happend to me. I solved it with a ceramic oil additive.Originally Posted by jaylebo
My engine has 225,000km on it (about 140,000mi). It's always been run on regular motor oil.
I've been told that, if I switch to synthetic now, I risk unclogging any number of engine leaks that are sealed with old sludge, creating a long-term nightmare.
Is it true?
Tell me more, man.Originally Posted by Interceptor
yes, tell us what you know!
^°^ ><((({º>°°
I did the change over to Mobil 1 synthetic 2 days ago. So far no leaks, but I'm sure it takes a while. I'll keep the forum posted if this changes.Originally Posted by jaylebo
How long did it take for your leaks to appear?Originally Posted by Interceptor
bought my car with 90k or so on it. put mobil1 in there, it leaked for about 15-20k, then the seals and rings were conditioned and it stopped. No leaks or any other problems when i sold the car at 218k
Read here: http://www.ferret.com.au/articles/48/0c035c48.aspOriginally Posted by Sharkman540i
or go to http://www.liqui-moly.de and choose English then Products -> Catalogue -> Additives -> Oil Additives.
It restored my compression, reduced engine noise and helped with the noisy/leaking hydraulic valve lifters. The procedure should be repeated every 50k km. Oh yeah, it improved my gas mileage and performance.
"CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines. Sufficient for 5 liters of motor oil. Operational area: CERA TEC is added to motor oil and is self-mixing. CERA TEC provides extreme wear protection for all moving parts and friction surfaces in the engine."
After the first 500 km it consumed around half a liter of oilOriginally Posted by uscharalph
I do have a slightly leaking valve cover gasket, but that shouldn't be the reason for that much oil consumption!
