its a 93 colt, use the sledge....
My friend's 93 Colt fails the ohio e-check.. and now it's become my issue
The first two test where before I messed with it
8-10-05 8-27-05
what reading limit what reading limit
HC 71.1 160 HC 75.1 160
CO 0.29 0.90 CO 0.30 0.90
NO 1713.8 1179 NO 1717.1 1179
Co2 14.86 n/a Co2 15.17 n/a
To me that screams overheat / egr value
So, I flush the colant, ran supercleaner, then normal cleaner with water. Took out the stat(yeah.. I know.. not very legit) and got this test with the clearer and water. The stat had some corrison on it... but it still worked.
8-29-05
what reading limit
HC 104.7 160
CO 0.23 0.90
NO 1491.3 1179
Co2 15.19 n/a
Thats a 225 point drop on NO, I need a 514 point drop to get 2 year ext.
The bottom rad house gets warm, so it is flowing. The valve cover gasket leaks on the car. The car doesn't even warm up to a 3rd with the stat out.. so it doesn't appear to be over heating.
The next things I swaping out are.
EGR Valve, Plugs, Dis Cap and Router.
Anyone got any great suggestions on what else to check with these numbers.
-Charles
I miss my e34
1994 540i Auto
live fast; die sideways
13.3 @ 104mph (not in the 540)
15.4 @ 150 Kph in the 540 (24/9/07)
carbon buildup in the passages of it and the head, clean them out if they are restricted or plugged up. Verify that all the vacum lines are ok and that the egr valve is functioning. Retarding the timing as much as you can stand will help but the egr really needs to be working too... You didn't specify whether it was the 1.5 or 1.8 so i assumed 1.5
Originally Posted by dacoyote
If it was mine.... it wouldn't even be worthy of risking missing up the sledgeOriginally Posted by stx133
-Charles
I miss my e34
Its the 1.5. Is there something nasty I can burn in it so I don't have to strip the car down that would help clean out any carbon in it? Do you have a guess on how teeth I can change the timing? (May be able to do that just poping the top timming best cover off)Originally Posted by Bill R.
Also.. any easy way to check the egr value, or is it best to just buy one... I have always just done the buy a new one style) I checked all the vacum lines and they look good (simple things first)
I miss my e34
just for the fun if it...
JP3CA11A0PU088851 if anyone whats to car fax it..
-Charles
I miss my e34
egr valve , you remove the valve and then clean the passages under the valve out and remove the carbon in there, not in the whole motor...
Also,
From Gayle's suggestion I got 4 bottles of auto-rx.
I am very intrested to see what it does.
-Charles
I miss my e34
