Originally Posted by
530iBall
1) I'm getting a little rust discoloration around the fuel filler door. I was thinking of sanding it down, using a rust inhibitor, and then touching it up. Is that the way to go? Any suggestions on rust products?
On my car I have been sanding it all the way down to good metal, then repainting. Make sure you new color matches the fade on the car.. or else you get something that looks like mine.
530iBall
2) I changed my plugs and the plugs on the passenger side towards the firewall were pretty oily. The car runs well. I've got over 150 K on her. Your suggestions would be welcome. Thanks
Value Cover Gasket like acyre said. Don't but this semi easy repair off. You can ruin coils, coil boots and the DME running the plugs in oil
-Charles
I miss my e34
