Results 1 to 5 of 5
Thread: Jammed shock rod nut
    Jan 2005
    Williamsburg, VA
    Default Jammed shock rod nut
    As I've posted before, I'm midway through a spring replacement job. I've successfully removed the rear suspension from the wheel well, and am having difficulty getting the nut off the top of the shock rod. Here's what I've done so far...
    - Soaked the area in PB Blaster
    - Compressed springs so that there is no pressure on upper spring mount
    - Used a 7mm wrench and a crescent wrench as pictured here. Nearly stripped the 7mm top of the bolt.
    - Wrapped the top of the strut with a strap wrench to keep it from spinning. Tugged away with a 20mm wrench.
    - Tapped 20mm wrench with hammer.
    Still no luck. Is there a trick to this, or do I just need to keep pulling? So far, the biggest difficulty in this project has been loosening nuts & bolts!
    Thanks again for everyone's help in this little project.
    Norman
    ukm5 Guest
    if ur replacing it cant you just cut through the nut with an angle grinder?
    ud find that the heat will generally free it up with grinding without damaging the surrounding panel
    Impact wrench
    best, whit
    Id drop it and impact it...
    edit: didnt I just hear an echo?
    Mar 2004
    Although I've never had this problem on a rear shock, on front struts I wrap an old leather belt around the shock rod as close to the shock mount as possible. Put a pair of vice grips over the belt and clamp tight. Use socket/ box end wrench on shock nut.
    Relaxing the spring tension before you loosen the nut may make it more difficult. Instead of using a 7mm wrench try a 6 point socket and breaker bar.
    Paul Shovestul
    Quote Originally Posted by ElNormo
    Norman
  1. Elec window jammed.
    By ss2115 in forum 5 Series BMW
    Last Post: 05-15-2009, 07:12 AM
  2. Gearbox jammed on the road!
    By MurderBlack in forum 5 Series BMW
    Last Post: 09-03-2008, 11:27 AM
  3. jammed CD player--how to fix?
    Last Post: 03-07-2005, 03:54 PM
  4. Trunk lock jammed
    By mikemaster in forum 5 Series BMW
    Last Post: 08-24-2004, 01:45 PM
  5. jammed ignition
    By jackieleung61 in forum 5 Series BMW
    Last Post: 04-19-2004, 09:18 AM
