WTF just happened? I replied to this WAY earlier and it says it was just posted...its either dyslexia again or that crack habit I havent started yet...damn.
I have two serpentine belts on my 1995 530i E34 M60 engine and therefore I have two tensioner pulley arrangements. I have two problems/questions with the tensioner pulleys.
One, Bentley says that I should be able to put a wrench on the nut of the pulley and rotate the tensioner so as to put tension of the bolt. But when I try to do this, the nut comes loose and I can’t apply tension. Does anyone know how to tighten the pulley for this engine?
Two, there is only a limited amount adjustment in the slot of tensioner pulley. When I bang up against the maximum amount of adjustment the belt is still pretty loose. The car will run fine but I hear it slipping once in a while. Could it be that the spring in the tensioner is bad or is this normal?
seems he posted 2 questions, which look the same on 2 occasions, this is the one u replied to
http://www.bimmer.info/forum/showthread.php?t=13533
