Results 1 to 10 of 13
Thread: my crazy 540I
    Aug 2005
    Default my crazy 540I
    Who can help me
    Hi all
    I have a 1995 e34 540I
    I have some problem on it
    when i drive and push petrol pedal the car want to go fast but the engine is off and on. whe i start the car at any time and drive on first push for petrol pedal the problem is not comming but when i stop and push agine the problem is comming.
    I toke it for a grages someone tell me its fule problem, you have a poor fule pump. someone tell me the problem from the fule regulator.
    I replaced the fule pump , fule filte , fule regulator , Idel air valve , clean the injectors , AFM , Engine DME and crank shaft sensor.
    I toke it to some grage have a computer to check it all diagnostic's didn't want to enter. they told me the diagnostic line is bloked or locked.
    I want to know whats the problem on my car and what to do to repair it and i want to know why the diagnostic line is bloked or locked.
    MY car vin no. gf07322
    and thanks for all
    please help me
    MR-540I
    Wellington,New Zealand
    o2 sensors????
    Quote Originally Posted by MR-540I
    Who can help me
    Hi all
    and thanks for all
    please help me
    MR-540I
    Only thing i can think of is take it to a BMW dealership. If you get different results from garages, go to the scource
    you have covered most everything that can go wrong, there are only a few other things to replace or check.
    Is there oil where the spark plugs go into the cylinder heads? If so then you will need to replace the valve cover gaskets. Also if there is oil there it can foul the spark plug boots, the coils and eventually the DME. I would check this first.
    The next thing to check is the crank sensor if it is loose and the wires coming from it to see that they are good and not torn or the insulation is intact.
    Aug 2005
    San Diego, Ca
    I have to agree with Paul...you did not mention 02 sensors....that is where i would start
    That and the ICV along with Intake Maniflold gasket... I think intake manifold is the culprit as air sneaking in cause wild problem... Make sure your intake boots from the air box to the meter to the intake is tight!
    For on board diagnostics to work, all modules on the network need to be responding.
    The same thing happened on my own car -- couldn't get any diagnostic computer to connect to it. The stupid previous owner had jumpered a wire at the driver's seat harness, messing everything up.
    The actual way to troubleshoot a non-connecting OBD is to pull each individual module in the car (about 13 of them in total) and see which one's causing the error. Should take a competent shop 6 hours.
    best, whit
    Aug 2005
    thanks for all
    but i disconnect the o2 sensor befor and i have no effects
    lowell
    maby am same your car previous owner,
    becuse i replace my seat by 1993 540i lather seats with heaters. i dont know if make problems for diagnostics or not.
    tell me what to do now??????????????????
    i want to reair my car
    thanks for all agine
    MR-540i
    thanks for all
    MR-540i
    there is no change when disconnecting the O2 sensors BECAUSE the car is running in safe mode...reboot the computer and see how it does.
    Did you check ANY of the things I previously posted?
    Aug 2005
    Thanks Regal for your help
    i disconnect the O2 sensor and i replaced them also but no effects.
    you mean i have to replace the O2 sensor and disconnect the ((DME)) --computer-- for a time ?
    but i want to tell you something
    when i colse the fule retern line the car is comming beter . why?????
    thanks Regal
    i hope you will help me
  1. Mechanic seemed to think i was crazy
    By Jehu in forum 5 Series BMW
    Last Post: 06-25-2007, 07:59 PM
  2. OT crazy
    Last Post: 11-09-2006, 10:05 PM
  3. OT, thanks but no thanks.... crazy people
    Last Post: 10-30-2005, 08:50 AM
  4. help me ... my 540i gonna crazy
    By ahmed18h in forum 5 Series BMW
    Last Post: 02-14-2005, 01:02 PM
  5. Crazy M30 valves :(
    By Kalevera in forum 5 Series BMW
    Last Post: 02-07-2005, 11:45 AM
