Results 1 to 10 of 15
Thread: Not starting
    Sep 2004
    Tasmania
    Default Not starting
    HI,
    I have a 1989 e34 525i auto and it will not start for me. The battery is fine, the engine cranks over but it just wont start. Seems like the battery doesn't have enough power but I know this is not the case because i tried to jump start it and it stil didn't work. Could there be something wrong with the ignition?
    have to start somewhere bro...
    spark, fuel?
    The last time it ran, were there any wierd occurances/noises...things of that nature?
    Jeff's on the money -- does it have a spark? how's fuel delivery?
    best, whit
    Sep 2004
    Tasmania
    Quote Originally Posted by lowell
    best, whit
    cranking over ok, except for battery gradually runnning down, no spark I think, fuel smell but not flooded, maybe fuse related?
    Whit did you get them new tires you were looking at?
    Aug 2005
    Quote Originally Posted by ken
    HI,
    Last time I had this problem, it was the crank angle sensor, or something of that sort. Can anyone confirm there is such a thing?
    Loving my Problem Child.
    M30 Manual / LSD / Prod. Date: 09-1989 / Basketweaves / Black Leather w/ rear headrests / Alpine Weiss III / 365k kms
    Sure!
    Any number of things...notably the crank position sensor, any of the critical relays, distributor cap and/or rotor. We talk about this stuff all the time.
    My concern with the last occurance of it running was that the timing belt may have snapped, which would likely trash the engine.
    best, whit
    Jan 2005
    quechee, vt
    small world, I had the exact same issue today....drove to work in a 1994 525it, car ran fine and I shut it off and went into work. I left in the afternoon and the car will not start. It cranks fine and just will not start. Watched it leave on a flatbed....any suggestions? Local shop mentioned something about a position sensor but hasn't looked at the car yet. Any idea what it might be and if it is the position sensor could it run fine until parked and what might it cost to fix? Thanks....Bill Mann
    the crank position is on the front of the engine usually above the harmonic balancer. Check if its busted, cracked, loose and also the wires coming from it.
  1. Car not starting...
    By Travis_WA in forum 5 Series BMW
    Last Post: 10-22-2008, 08:23 PM
  2. Non starting M60
    By Sidney Rough-Diamond in forum 5 Series BMW
    Last Post: 01-28-2007, 04:46 PM
  3. Car NOT STARTING!
    By JAK in forum 5 Series BMW
    Last Post: 10-11-2006, 11:14 AM
  4. Starting, need help
    By zivac05 in forum 5 Series BMW
    Last Post: 07-12-2006, 02:27 PM
  5. car not starting right away
    By wang540 in forum 5 Series BMW
    Last Post: 11-17-2005, 09:07 PM
