hmm...might be the power steering pump...check under the dash for a large nut behind the steering wheel and give it a few twists. If that dont help repost what you did and we'll try to help again.
Good luck!
My rear differential broke unexpectedly, took it to a shop and found out that it was leaking because of a crack. Had to replace it
I also just had my transmission rebuild, could the two be possibly related? I never had any problems with the differential before.
Ever since I got the car, I had problems with the idle. It was pretty rough, lots of vibration. I changed the engine and transmission mounts, didnt do much...Anybody know what might be the problem?
Good luck!
to many a relative.
The loose nut behind the wheel is always my first suspicion during any trouble shoot session.
it helped my car more than any suspension upgrade or when I redid the trans and rear end mounting bolts.
Er this thread seems to have taken a turn into the woods?
Tiger woods is supposed to be off for a few weeks.
Jeff
Are they on prescription?![]()
All the best
Bob
The nut behind the steering wheel has been the casue of all my problems.
By the way, Jeff. I've still got that halogen fluid sitting in my garage. I think you mentioned that your lights are running a little low?Originally Posted by 632 Regal
PM me if you still want it.
best, whit
Hey Bummer you tighten the steering nut yet?
