Results 1 to 5 of 5
Thread: Removing bolt on rear suspension to trailing arm
    Jan 2005
    Williamsburg, VA
    Default Removing bolt on rear suspension to trailing arm
    I'm mid-way through a spring replacement. I've got the car jacked up, the 3 x 13 mm bolts removed at the top of the suspension, and am working on the monster 22mm bolt connecting the suspension to the trailing arm. I've doused it in WD40, but cannot get it to budge. I'm using a crescent wrench, and have tried tugging and tapping it with a hammer.
    Any other ideas or tricks to get this bolt loose? I've heard that removing the suspension from the trailing arm is even more fun, but I'm stuck at this step.
    Thanks again for any help,
    Norman
    Aug 2005
    east anglia uk
    Quote Originally Posted by ElNormo
    Norman
    brute force and arms like the governator
    Norman...
    Get a box end wrench and a hammer. One of the other guys at the shop showed me a way of interlocking two combi wrenches together to get extra leverage; very handy but kind of hard to describe.
    WD-40 isn't good stuff for this application. Get a can of PB Blaster. Also, depending on where you are in the world, there's the possibility of the strut being fused into the trailing arm. If it's rusted together, take a hammer and pound on the surfaces to knock the rust loose. I sometimes use this trick on rusted bolts, as well. EDIT: also, I know that in my writeup I mentioned using a puller to remove temperamental rear struts; subsequently, I've learned that such a device won't work because there's no place for it to grab on the chassis side of the strut -- the metal "ring" isn't welded into place on the stock boge automatic, from what I recall.
    best, whit
    Quote Originally Posted by lowell
    Norman...
    best, whit
    I'm back from my road trip, quickly checked the site and noticed this post. If I'm readin this correctly, you're saying that a conventional puller won't work on a tempermental strut. A while ago, I posted the method I used to overcome this apparently troublesome scenario. The link is below. If I've interpreted your post incorrectly, my apologies, but maybe this will help anyway.
    pics of my trip to follow
    http://www.bimmer.info/forum/showthr...3478#post63478
    Dave M
    Dave M
    Dave, you're absolutely correct in that it works, I agree with you and the process, and that it might work in this scenario. I was mistaken in saying that it "won't" work.
    My qualm with the method is this: sticking a puller on it has the potential for disaster -- The one time I attempted it, the flat metal "washer" on the chassis side of the strut practically popped off (because the rubber bushing between the metal cylinder and the strut "walks"). That wouldn'tve been a problem in the scheme of things, but it leaves the metal cylinder in the trailing arm, which can be difficult or impossible for a DIY to remove. In the aforementioned case, I ended up getting out the air hammer and the 3' prybar. But yes, the method is something to try...just have to be careful.
    Nice diagram, by the way
    EDIT: actually, by sinking a screw through the thing as shown in the diagram, the puller idea would work great.
    best, whit
  1. Replacing rear trailing arm...
    By anonymous1 in forum 5 Series BMW
    Last Post: 06-01-2009, 05:27 AM
  2. Broke a rear differential carrier bolt.
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 06-10-2007, 02:46 AM
  3. Removing rear shock lower bolt thing
    Last Post: 10-28-2006, 12:28 AM
  4. Rear suspension struts removing -93 520iATouring.
    By tibbe in forum 5 Series BMW
    Last Post: 08-08-2006, 11:29 AM
  5. HELP! removing self leveling suspension.
    By abdeweese in forum 5 Series BMW
    Last Post: 07-30-2006, 09:42 PM
