Why would an M50 be firing 180 degrees off. Because it if firing 180 off i know my crank position sensor is right. And i know that the cam position is in the right place. Is it possible for the cam position to be showing the opposite signal it should be? Maybe I should just swap my coil and injector wires around to make it work, or is there a simple solution to my problem?
