Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 79
Thread: 1994 530i rough idle, cylinder miss?
    Aug 2005
    North East Florida
    whistle is not normal,
    Good to know.
    PCV Plate/Gasket, etc. on the parts list... Thanks!
    baton rouge, loserana
    the o-rings are on the 6 cylinder, the v8 just has a smaller gasket that rings the whole plug area and comes with the valve cover gasket, 11 rubber grommits per valve cover for each nut don't come with the gasket kit but they should, they are what actually applys pressure to the valve cover and reusing the old ones can cause problems with possible leaks
    Quote Originally Posted by Been-Jammin
    I didn't see the "O" ring Valve Cover Grommet Gaskets, would have completely over looked them, thanks Lowell for adding that in! Wow, 22 of them.
    IMPORTANT!!! Remove Bosch 4417 Platinum +4. BMW do not like them at all... Reinstall factory standard plugs.
    Aug 2005
    North East Florida
    Quote Originally Posted by Tiger
    Thanks! I know how cars can be picky about plugs. I appreciate the insight.
    I'll pick up a set of Bosch F7LDCR's for this weekend's project work. Going to have them out to do the compression and leakdown tests anyhow.
    After you replace (or before) the gaskets reboot the thing. When my intake was leaking last winter it ran just like yours, check light, the miss, everything. I rebooted the computer and it read that the leak was a "normal" leak and the car ran a lot better for several months until I got to the gaskets. When I had my intake off there was one of them air horns rolling around in there and that could have caused the intermittant miss by blocking an intake port.
    Before that after I bought the car it had a real bad miss that I chased with coils, plugs, Injectors only to have the same miss which was "Caused by Nikasil" until I replaced the plug boots...they all checked out with the ohm meter but the new ones solved the whole dilema...40k or so ago.
    Also, them specialty plugs can cause strange idle/miss problems, stick with the stocker plugs.
    Good luck to you!
    Aug 2005
    North East Florida
    Default Silly Question: How do I "reboot" it?
    Good luck to you!
    Silly Question: How do I "reboot" it? Do I disconnect the battery? (I have the radio codes) I know the battery is located under the rear seat, but honestly, I've never seen it for myself.
    you can unplug the computer which is under the black cover on the right side under the hood and not effect the rest of the car, the engine computer should be the one closest to the windshield, unplug for a minute or so and it's done
    Ah, I'd still take it to a good indy and have them stick it on a machine. If the check engine light was ON, there's a stored code.
    http://www.iaibmwsp.org
    There should be someone in there who can read the codes for you. Local auto parts stores...hehe...well, they're usually a bad place to go for anything BMW.
    best, whit
    any vacumme related ill effect will result in the O2 code...which is irrelivant at this time. Either pull the computer out of the box or disconnect the battery for like 30 minutes...there is Shoguns reset which involves crossing the cables (after disconnecting them of course) and discharges everything, that seemed to make a greater difference than just disconnecting them.
    Aug 2005
    North East Florida
    Thanks! I disconnected the computer, which no doubt cleared the codes. It's showing 1444 now. The check engine light only comes briefly when warming up and first hit's the "closed loop" coming out of "warm up" mode. Will have to see how it does in the morning and go from there. I took a 1/2 hour drive this afternoon and nothing unusual, no engine light either.
    I've ordered all the intake gaskets, etc. including plug boots so should have a nice weekend project coming up. I'll have the leakdown tester by then as well. I figure it's worth it at this age/mileage if nothing else to clear my head of worry.
  1. Rough idle problem M60, 530i
    By Rusty Bavaria in forum 5 Series BMW
    Last Post: 02-04-2008, 02:15 PM
  2. M20 Rough Idle
    By EngPhys09 in forum 5 Series BMW
    Last Post: 10-29-2007, 10:21 AM
  3. 1994 E34 530I Fluctuating Idle (CONTINUES)
    By Green Bimmer in forum 5 Series BMW
    Last Post: 02-23-2006, 06:52 PM
  4. Fluctuating Idle 1994 BMW 530I E34
    Last Post: 02-21-2006, 02:39 PM
  5. Random miss at idle
    Last Post: 08-12-2005, 05:17 AM
