Originally Posted by
Been-Jammin
....up. The cylinders nearest the firewall had some standing oil around the spark plugs when I pulled them out. ...
That oil is from a leaky Valve Cover Gasket, it's easy to replace and doesn't cost that much if you DIY. The bad new is that you may ruined a coil or the DME. There isn't a really great way to test without swaping them out with good ones.
Been-Jammin
....I read that to check the engine codes, simply turn the key on (without starting) and depress the accelerator pedal 5 times within 5 seconds. I tried that several times to no avail. Can anyone tell me how to display the codes?
Thats how you do it... it's a PITA to get it to work (or at least for me)... you need to make sure the petal is hitting the kick down switch... some of the times it takes either slamming it really hard.. or just a nice set of five solid clicks
Been-Jammin
....I was going to do a vacuum check and have been hard pressed to locate an exposed vacuum line. Does anyone know of any "easy to spot" vacuum leaks?...
HAHAHAHAHAHA... sorry there mate, shouldn't laugh.. get out some carb cleaner... spray it arround and listen for the idle to change.
-Charles
I miss my e34
