Results 1 to 9 of 9
Thread: Peeling Clearcoat.
    Aug 2005
    Default Peeling Clearcoat.
    I have a patch of clearcoat missing on a door. Any thoughts.
    Ouch!
    Get some estimates, should be able to scuff it up, sand and respray.
    Texas
    The only option you have is to repaint the door.
    Aug 2005
    Ok. Thanks. Does anyone know if it will just continue to peel? I'm undecided as if I'm going to attempt and keep the car nice and perfect or not. My goal is to just have a solid nice car that will run for a while. So, it may not be worth fiddling with at the moment.
    I would get some estimates and listen to the way they would repair this and make a decision based on that. might only cost you a hundred bux mattering on technique.
    Aug 2005
    That's a good idea. Thanks.
    Default Yes it will continue to peel, mine did.
    Quote Originally Posted by olsan100
    Texas
    The clearcoat will continue to flake off as time progresses or until it progresses to a point to were it hits clearcoat that was applied properly.
    Dunlap Illinois
    The old peeling clearcoat must be sanded down and removed in order for any new finish to stay. Otherwise the new finish would just peel away too.
    It's one of those things about owning an older car that was made before the introduction of the modern day clearcoats. The clearcoats of today are 100 times better than the clears they used on our E34's.
  1. Clearcoat?
    By m5maniac2001 in forum 5 Series BMW
    Last Post: 03-21-2005, 12:12 PM
  2. Peeling interior door panels
    By jpkasper in forum 5 Series BMW
    Last Post: 11-19-2004, 02:51 PM
